Connecting rod to camshaft clearance |
keske968 |
Oct 3 2012, 06:37 AM
Member Group: Members Posts: 132 Joined: 5-September 06 From: Papillion, Ne Member No.: 6,778 Region Association: None |
I am building my own engine and have a question that I can not find the answer to on the searches that I have done. When putting in a stroker crankshaft one of the connecting rods comes very close to hitting a camshaft lobe. What is the recommended clearance between these two parts? I know that they will expand slightly when the engine warms up and currently we only have .006" between them. I am concerned that this is not enough clearance.
Thanks for all the help you guys provide. |
two-strokejohn |
Oct 3 2012, 07:49 AM
Member Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States |
http://www.ephotomotion.com/914engine/index.htm
check out this web site . I think it is covered there.......... good reading on a rebuild. |
ChrisFoley |
Oct 3 2012, 09:19 AM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I don't allow less than .030".
keske968 |
Oct 3 2012, 09:40 AM
http://www.ephotomotion.com/914engine/index.htm check out this web site . I think it is covered there.......... good reading on a rebuild. I have used his site extensively (great resource) and it looks like he only allows for .008" clearance. I was not sure that was enough to cover the thermal expansion. |
ChrisFoley |
Oct 3 2012, 10:16 AM
I'm more concerned with crank flex than thermal expansion.
The case is certain to grow more than the camshaft or crankshaft/rods, which would move them further apart. |
Mark Henry |
Oct 3 2012, 11:57 AM
I don't allow less than .030". (IMG:style_emoticons/default/agree.gif) Web cams for "larger displacement engines" have a reduced base circle thus helping with rod clearance, after that you have to start removing material from the rod itself. |
JoeSharp |
Oct 3 2012, 08:41 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Had a motor that had a shinny spot on a cam lobe and never heard a thing from it. It was being touched by a rod nut.
Lo-Fi Version | Time is now: 9th May 2024 - 08:41 AM |
