Waxing Old Garaged Car - Compound and Wax? |
kbrunk1 |
Oct 7 2012, 06:05 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Have an old car that has been garage kept but faded.
I have some compound and wax. Does anyone have a better recommendation? |
rick 918-S |
Oct 7 2012, 06:11 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
What kind of car? 914 or..? Original paint? Let's see it. It makes a difference. |
kbrunk1 |
Oct 7 2012, 09:09 PM
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) What kind of car? 914 or..? Original paint? Let's see it. It makes a difference. Original paint. Baha Red. |
Mike Bellis |
Oct 7 2012, 09:24 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Rubbing compound can go really bad if you're not careful. I would try wax first and if it won't shine, mild rubbing compound. Best way is to go back and forth not in circles.
sixnotfour |
Oct 7 2012, 10:09 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Boiled Linseed Oil (IMG:style_emoticons/default/smile.gif)
Attached thumbnail(s) |
tod914 |
Oct 7 2012, 10:10 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
PS21 paint cleaner with Mequires scratch remover might yeild you good results. 50/50 dab of each. You can clay bar it first to get rid of some of that surface residue. Try a small section and see how it comes out. Least aggressive, then go from there.
rnellums |
Oct 8 2012, 09:11 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
No expert, but I would say wash, and then clay and see how it looks. If its still bad, start with the least aggressive compound you can find (polishing not rubbing) and do the whole car by hand. if still not good enough go one step more aggressive and go over the whole car, then follow with the polish. Still not good enough? one more step aggressive and repeat. On my car I used Mcguiar's ultimate compound followed by ultimate polish. Going by hand takes forever, but thee is less chance to burn through the paint.
rick 918-S |
Oct 8 2012, 10:17 AM
Most compounds today are designed for clear coat finishes. These are very mild as you are usually working out 2000 wet sanding scratches not breaking through dead chalked color. The oxidized red paint may need a more aggressive product to cut the finish. I would use a wool pad to start. The caution will be all the crowns and edges will likely loose the finish if your not careful. But old paint is old paint. Give it a shot. If you can wake it up one more time I'd say it's worth the chance. Take your time, clean, clean, clean before you start. Once you break the dead paint clean again. Then you may want to wet sand with 2000 grit paper and start working it with a staged foam pad set and finer clear coat polishing paste. It's not a ten minute deal.
Lo-Fi Version | Time is now: 20th May 2024 - 02:57 AM |
