Master Cylinder Brake Warning Reset Button? |
kbrunk1 |
Oct 8 2012, 10:11 PM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
Finally bled my brakes correctly but the light still flashes on the top of the tank level.
Anyone know how to reset the brake warning light? |
WFG |
Oct 8 2012, 10:19 PM
Newbie Group: Members Posts: 29 Joined: 6-December 05 From: nashville tenn 37076 Member No.: 5,243 |
Reset button on master cylinder if it does not have one try unpluging the wire at master cylinder and plug it back in then check parking brake switch.
William |
FlatSix |
Oct 9 2012, 02:42 AM
English Member Group: Members Posts: 191 Joined: 14-January 03 From: Poole, England Member No.: 144 |
I was just going to start a new thread when I saw this. Seems I'm not the only one having issues here!
I've just installed an ate 19mm master cylinder. However there doesn't seem to be a way to reset it. I've pulled off the little black rubber protection sleeve to reveal this. It seems to be one piece of white molded plastic, not a switch. Any ideas? Attached thumbnail(s) |
kbrunk1 |
Oct 9 2012, 04:36 PM
Pull the emergency brake and release it and clip your seat belts.
it is magic! |
Dave_Darling |
Oct 9 2012, 09:07 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I've pulled off the little black rubber protection sleeve to reveal this. It seems to be one piece of white molded plastic, not a switch. Any ideas? The middle of that white plastic piece is a button sticking out. Press the button. And yes, make sure the hand-brake is released. --DD |
FlatSix |
Oct 11 2012, 10:18 AM
Well I guess it's pressed. It didn't seem much of a switch to me...
I still get a buzzing - relay rapidly clicking - when the handbrake is applied. This goes to the normal speed of clicking when indicators or hazzard flashers are in operation. Is this related to the new master cylinder? It is the only thing that's changed so I'm thinking there might be a connection. |
Valy |
Oct 11 2012, 11:18 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I still get a buzzing - relay rapidly clicking - when the handbrake is applied. The warning should be on when the handbrake is applied as well as when there is low pressure in the braking system. Same indication for 2 different reasons. That's the way it's designed. |
Lo-Fi Version | Time is now: 29th April 2024 - 07:12 AM |
