Tin misaligned? |
Tin misaligned? |
ruddyboys |
Oct 9 2012, 07:19 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Putting the engine tin back on. Have it all screwed on except there is a problem by the intake. It a bit low on the left side by about 1/8 ". Took it off and tried twice. should I just dremel of the overlapping tin and call it a day. or pull it all apart and try again.
Attached thumbnail(s) |
reharvey |
Oct 9 2012, 07:31 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
I've had this problem a few times. Just trim off the part that overlaps the intake flange. Ray
gothspeed |
Oct 9 2012, 09:53 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Once you install the screw (all the way left in your pic). then just trim off whatever encrouches onto the intake mounting flat.
wingnut86 |
Oct 9 2012, 01:53 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Heavy tin snips work good for this, Dremel if you have a steady hand...
TheCabinetmaker |
Oct 9 2012, 02:11 PM
It should not have to be trimmed. It just needs to be repositioned slightly. It appears to too far to the right, or the rear if I'm seeing correctly. Loosen the screws and move it toward the front of the car.
Oct 9 2012, 02:12 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Putting the engine tin back on Did it fit before? If so, what changed? If it used to fit, i wouldn't be so quick reaching for the dremel ... (IMG:style_emoticons/default/idea.gif) |
Kirmizi |
Oct 9 2012, 02:30 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Mike |
Lo-Fi Version | Time is now: 8th May 2024 - 06:55 PM |
