markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
I am soooo glad I've got good insurance.....and that my better half is a Dental Assistant. (IMG:style_emoticons/default/wink.gif) I just gotta be careful not to piss her off before I have to go for a cleaning.... (IMG:style_emoticons/default/wacko.gif)
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
$800 for a crown is about right. i've turned lots of big, old, fillings into crowns
bperry |
Lurker ![]() ![]() Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 ![]() |
I had a similar problem over a year ago.
A piece of my tooth broke off while eating a sandwich. I ended up with a crown. I chose porcelain rather than gold. It looks nicer - can't really tell its in there. But porcelain is much harder to fit properly and it costs alot more. Mine was about $1300 1 year ago. In my case the tooth was perfect other than one of the points sheered off. Once the dentine is exposed, you have to get a crown. (Don't get the tooth pulled) The filling technology isn't there yet to cover this up or repair this type of problem. Since I had so much tooth still left, I spent over an hour in the chair while the dentist grinded down my almost perfect tooth down to a "nub" for the crown. Since mine didn't hurt I actually wen't about 6 months after the break (till the next dentist visit) before I got the crown. I didn't actually know it was as bad as it was. All you can do is bend over and open your wallet. --- bill |
JB 914 |
Daddy! Finish my car NOW!!! ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 ![]() |
had almost the same thing happen to me. They may be able to get a crown on it. That's what i did. Not cheap though.
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Sean
Here's the skinny. Your dentist may or may not tell you all of this cause we all do things a little different. My practice is real blue collar and I often have to cobble things together so I would consider the first 2 while many dentists might not even mention them. Course I haven't seen your tooth but usually when that tooth breaks it's because of clenching or grinding and there is very little decay to remove. If it just busted then here are your choices. 1) Composite filling - don't waste your time these are no good in large fillings and you will do it over very soon. 2) Silver amalgam filling - cheap and quick, your dentist will not want to do this cause there isn't much margin. It can work pretty well but there are no guarantees. If you do this and want a crown in the near future (a couple of years) you can use this as the foundation for that. 3) Gold onlay - like a bikers skid lid, it only covers the top (biting surface) of the tooth. Saves a lot of enamel. My favorite cause I know I can't make anything as good as nature did and the gums love enamel not gold or porcelain. 4) Porcelain onlay - same as above but solid porcelain. Probably, the treatment of the future. It's a little more risky than gold cause it can crack and sometimes the cement fails and the tooth gets real sensitive. 5) Gold crown - old standby, it has the longest history. It will work well. The dentist probably will like this. Easy and pretty good profit. 6) Porcelain bonded to metal crown - looks better than gold. Dentist really loves this $$. Probably will work well. My preference, use gold over porcelain cause it is better to bite on in the back tooth. It will not break and the wear rate over the years will match the rest of the teeth. The porcelain on the porcelain bonded to metal crown will wear down the opposing tooth if you grind your teeth at all and most people do. Porcelain onlays wear the opposing tooth less but are more likely to break. How much decay is in the tooth is the kicker. If there is none all of the above probably can be considered but, as the decay increases, the choices decrease until you have to chose between the crowns. Lots of decay equals root canal. Lots and lots of decay and you need the tooth taken out. Sorry for your bad luck Dave |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
Can't add much to the pro advice from Dave
I've got 8 crowns (front upper teeth). Metal core with porcelain shell. They're great I was lucky and got them for free... good to have a dentist among your clientelle (IMG:style_emoticons/default/biggrin.gif) So, if there's enough left from the tooth, get a good crown. It'll cost you, but you won't be sorry later Enjoy the pain (IMG:style_emoticons/default/biggrin.gif) |
rhodyguy |
what's the mark up on a porcelain bonded unit? you get to look like a pirate or flavor flav with gold crowns. arrrgh, heyyy boyzzzz!!!!
kevin |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Dave,
I think you nailed it with the grinding. I do grind my teeth, and it is usually in the back of my mouth. #2 sounds like it could be the way. (IMG:style_emoticons/default/confused24.gif) Jeroen, the thing doesn't hurt at all. none. period. wierd, huh? |
Jeroen |
QUOTE(seanery @ Nov 1 2004, 04:26 AM) Jeroen, the thing doesn't hurt at all. none. period. wierd, huh? Good for you (and I mean that) I have bad teeth. Not because of neglect but by genetic design (they have a tendency to rot from the inside out) and I've spend many hours in the dentist chair Just 2 months ago, I had a jaw infection. Didn't hurt, but I looked like a friggin hamster (IMG:style_emoticons/default/biggrin.gif) I got a root canal, without anesthetic. Didn't feel a thing. Nerves were dead as a doornail... Good luck at the dentist! |
aveale |
Fun Times ![]() ![]() Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 ![]() |
I had to read this thread.
Looks like you got all the info you need - some people actually listen when they are at the dentist!!! If there is anyway I can be of service................ T |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Dood! I am so sorry! Glad you aren't in pain though!
When I was a kid, me and another kid were throwing a basketball back and forth.... my grandmother called my name, and I looked.... then as I looked back... my friend had a puzzled look, and empty hands.... and that is when the ball whacked me in the top of my head, chipping off half of two front teeth... (IMG:style_emoticons/default/smile.gif) Root canals are fun! I love IV sedation, even if it's more expensive, and you have to go to a surgeon. M |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
QUOTE Course I haven't seen your tooth but usually when that tooth breaks it's because of clenching or grinding I guess I should start wearing my Doctor's® Night Guard again....my wife loves when I wear it, she gets a better night sleep since I don't wake her up grinding my teeth......but I don't like it...oh well, if it'll prevent damage???? |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
QUOTE(skline @ Oct 30 2004, 11:08 AM) Prilosec absorbs the calcium from your body, I guess not everyone but most it does, they wont say anything about it because of the market share they have. "absorbs the calcium from your body" ?? where does it go ? if "they" won't say anything about it, where do you get your information ? so far this has all the earmarks of a conspiracy-theory urban myth -- but if you've got a reference to point me to, i'll definitely check it out... i'm not saying it isn't true, i'm just saying "show me the data ..." |
seanery |
soooo, for all of you who don't do what smart dentists on this bbs say, you will pay the price. I've had terrible pain in my mouth for the last couple days. I thought it was from the lower left part of my mouth. Went to the dentist today and he insists it's because of the broken tooth.
oooffff, damn, it hurts, at least I'll get some Tylenol 3 with Codein. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) oh, and the tooth has to come out (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
if you need a implant, my dad could do one for you. |
dwillouby |
Member ![]() ![]() Group: Members Posts: 394 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None ![]() ![]() |
Gotta go tomorrow for dental work. Been putting it off for a couple of weeks. The whole side of my head hurts.
David |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
Any of you dentist folks, is it odd that his tooth just broke on a french fry? Seems odd to me, but then again, I don't see this stuff everday.
seanery |
My dentist told me that it was probably decayed inside and didn't need much to cause it to actually break. |
KaptKaos |
Sometimes these things are signs of a different issue. Be sure to get checked out. |
seanery |
Dave Hunt nailed it with the grinding. I got a pretty long lecture on stopping that today.
Lo-Fi Version | Time is now: 3rd July 2025 - 12:21 AM |
