What's the best radiator set up?, Most efficient set up for overall cooling, airflow ect... |
Fastcruisin914 |
Oct 13 2012, 12:53 PM
Newbie Group: Members Posts: 3 Joined: 13-October 12 From: USA Member No.: 15,031 Region Association: None |
I am doing a Subaru conversion, and am looking for the best proven cooling system.
I have seen the Renegade Hybrid kit, worth the cost??? I have also seen some refer to Desert hybrid, are they still even around or doing 914 radiator kits, and if so are they any good? So many factors like, front trunk radiator set ups, or rear truck set ups? The angle of the radiator in the front truck, straight up against the front saving trunk space, or sitting back further and angled, or even in the floor of the trunk? Also with the air flow, big cuts in the wheel wells, or many holes in the wheel wells, or venting through the trunk floor, or through the hood with the air going up, what is the best way for the air flow without taking from the vehicle structurally? Pictures would be nice, or even something that may show the step by step process from start to finish with the cooling system install/fabrication. |
dakotaewing |
Oct 14 2012, 07:43 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
I have been doing a little research on this subject, trying to come up with some options... Found this today. It's a perfect fit, and about 1' wider than the Renegade set up. Some folks also make shroud's for this radiator, but the fans seem cheap. Cost for the radiator is about $120 shipped.
Attached image(s) |
pete |
Oct 15 2012, 02:49 PM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
I have been doing a little research on this subject, trying to come up with some options... Found this today. It's a perfect fit, and about 1' wider than the Renegade set up. Some folks also make shroud's for this radiator, but the fans seem cheap. Cost for the radiator is about $120 shipped. Where did you find it? Link? |
dakotaewing |
Oct 15 2012, 06:42 PM
Ebay. Search 00-05 Toyota Celica Aluminum Radiator
Lo-Fi Version | Time is now: 12th May 2024 - 09:00 AM |
