What's the best radiator set up?, Most efficient set up for overall cooling, airflow ect... |
Fastcruisin914 |
Oct 13 2012, 12:53 PM
Newbie Group: Members Posts: 3 Joined: 13-October 12 From: USA Member No.: 15,031 Region Association: None |
I am doing a Subaru conversion, and am looking for the best proven cooling system.
I have seen the Renegade Hybrid kit, worth the cost??? I have also seen some refer to Desert hybrid, are they still even around or doing 914 radiator kits, and if so are they any good? So many factors like, front trunk radiator set ups, or rear truck set ups? The angle of the radiator in the front truck, straight up against the front saving trunk space, or sitting back further and angled, or even in the floor of the trunk? Also with the air flow, big cuts in the wheel wells, or many holes in the wheel wells, or venting through the trunk floor, or through the hood with the air going up, what is the best way for the air flow without taking from the vehicle structurally? Pictures would be nice, or even something that may show the step by step process from start to finish with the cooling system install/fabrication. |
A&P Mech |
Jul 28 2016, 07:12 AM
Member Group: Members Posts: 400 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
If you have access to a MIG and are willing to fab a bracket and cut some sheet metal you can have a radiator assembly for a little over two hundred bucks. I put mine together using the Toyota Celica GT radiator off of eBay. It cost $167 bucks and it comes with fans and shroud. I have a 2.5L Subaru in my car and it runs 190 degrees even in 95 degree heat.
I found that it that it doesn't take a large opening to provide more than enough air to keep things cool. |
Lo-Fi Version | Time is now: 12th May 2024 - 11:57 AM |
