Fuel pump relocation wiring question, the wiring is done I have a new question! |
SLITS |
Oct 27 2012, 07:28 AM
Scott, thanks for following up on your progress! I have finally mounted my fuel pump under the steering rack. So far I think I will be running 12v power to the pump from the battery using a relay. The relay will in turn be triggered by the factory harness wires for the orignal fuel pump. Since I am going with carbs for now, I will be going with the extra ground from the relay panel in the engine compartment. Did you run fuel pump power with the 'key only' or did you also include an oil pressure switch to control power to the pump? If you included an oil switch in the circuit, how was it done? I am under the impression the the swtich is open under pressure, which is the opposite of what one would need to complete the circuit. It's been a long time, but the switch has contacts for NO and NC. The NC powers the pump while turning the starter. Once the engine fires and you have oil pressure, the NC opens and the NO closes to provide continuous power to the pump. |
Oct 27 2012, 11:35 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Why not just run both ground and positive leads from the engine compartment to the steering rack area? That also works. A ground is a ground, so you can run a new ground wire from the old one, or you can just run a wire to any convenient ground. And the chassis itself is a ground, so that can be just about anywhere. --DD |
gothspeed |
Oct 28 2012, 02:36 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
It's been a long time, but the switch has contacts for NO and NC. The NC powers the pump while turning the starter. Once the engine fires and you have oil pressure, the NC opens and the NO closes to provide continuous power to the pump. Just to be clear ........... we are talking about the ignition switch that has the NC and NO options correct? I am running D-jet so I am wired to the fuel pump terminal on the relay board. OK thanks! I was working on the fuel lines this morning ..... (IMG:style_emoticons/default/smile.gif) |
scott_in_nh |
Oct 29 2012, 12:09 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
So it is on the ground and running again. (IMG:style_emoticons/default/biggrin.gif)
I only had time to take it to the gas sation and back before having to start preparing for the storm. The shifter still needs a slight adjustment, but I think it is already better then it was. The console still has to go in once the shifter is done. The limited cornering I've had indicated a major change with the front bar in! (IMG:style_emoticons/default/driving.gif) I don't usually lose parts, but I've misplaced the "buckle" end of one of the gas tank straps, and the car already was missing the strap for the carbon cannister. If anybody has those parts let me know. I'll be posting a WTB. Scott |
gothspeed |
Oct 29 2012, 08:33 PM
Drilled some holes and put some grommets in them. Getting ready to route wires, what gauge wire did you use or recommend? I was thinking 16g wire for my cb performance 3.5psi pump. Even though i am using a relay next to the battery, the pump is way up front next to the steering rack. Does anyone see a problem with 16g? Should i go with bigger wire? (IMG:style_emoticons/default/unsure.gif)
SLITS |
Oct 30 2012, 06:49 AM
gothspeed |
Oct 30 2012, 07:45 AM
I was describing an aftermarket fuel cutoff switch. What wire gauge do you recommend for a front mounted carter/CB performance 3.5 PSI fuel pump which is powered from the stock battery location? |
SLITS |
Oct 30 2012, 10:46 AM
14 or 16 .....
gothspeed |
Oct 30 2012, 11:36 AM
14 or 16 ..... |
76-914 |
Oct 30 2012, 11:54 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Your fuse needs to match the wire size. The wire size could be anything from 2 ga to 18 ga but if your fuse size doesn't match or is too large then the wire becomes your fuse.
gothspeed |
Oct 30 2012, 12:24 PM
Your fuse needs to match the wire size. The wire size could be anything from 2 ga to 18 ga but if your fuse size doesn't match or is too large then the wire becomes your fuse. http://www.tessco.com/yts/industry/product.../get_wired.html Edit: Looks like the Carter/CB Performance 3.5 PSI fuel pump instructions call for a 3 amp fuse and 16 gauge wire. I will run a 14 gauge wire as Slits suggested, so in the future when I go fuel injection (more powerful pump) ...... I should not need to run another wire, only up rate the fuse ....... (IMG:style_emoticons/default/smile.gif) Thanks to all who have posted info!! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 11:42 PM |
