FS: 2.0L FI pkg., * SOLD * |
914werke |
Oct 14 2012, 11:27 AM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Here is a COMPLETE OE D-Jet FI package off of a 1976
Items you want to ensure you get in any kit (too often combinations are offered but omitting specific pieces) include: Electronic Control Unit & Bracket Injection harness Manifold pressure sensor Distributor (w/trigger points & vacuum advance) Cylinder head temp Sensor Fuel pressure regulator Intake runners (x2) Plenum (correct for MY) Air box (correct for MY) Oil fill tower (with PCV valve->74) Fuel injectors (x4 Green 2.0L, Yellow=1.7L) Fuel injector clamps (x4) Fuel line clamps (x14 OE w/rolled shoulder) Fuel rails (x1 straight, x1 T'd) Flashback valve (->74) Deceleration valve Throttle body Throttle position switch Thermo-time switch (specific to MY) Cold start injector Intake air temp sensor Auxiliary air valve High pressure Fuel Pump Consumables (items not necessarily included & you'd probably want to replace): Fuel Filter Fuel Lines (7.5mm) Air Filter Throttle Body Gasket Vacuum lines (various size & length) Injector seals (4) PCV valve (depending on MY, if you can find one, otherwise disassemble clean & reuse) Intake / plenum seals (4) Phenolic spacers (2) Late cars had additional emission equipment, Air pump Brackets & piping CA cars had further plumbing and electronic Gee-Gaa's including a specific Gauge bezel with idiot lights, Dual speedo cables with trip computer EGR sensor in a dual chamber muffler EGR piping to that muffler Attached thumbnail(s) Attached image(s) |
914werke |
Oct 16 2012, 10:06 AM
If you make the modest increase to 2054cc will this accommodate it? p.s. This is one of the best running systems I have ever driven. I have a 76 with this FI, and it starts every time on the first try. Sort of like a modern car. Do you mean 2056? (IMG:style_emoticons/default/idea.gif) (96mm pistons & cylinders) all things being equal yes, Ive done several updates w/96's & kept the stock D-jet injection. (IMG:style_emoticons/default/sunglasses.gif) |
worn |
Oct 16 2012, 10:50 AM
can't remember Group: Members Posts: 3,154 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
If you make the modest increase to 2054cc will this accommodate it? p.s. This is one of the best running systems I have ever driven. I have a 76 with this FI, and it starts every time on the first try. Sort of like a modern car. Do you mean 2056? (IMG:style_emoticons/default/idea.gif) (96mm pistons & cylinders) all things being equal yes, Ive done several updates w/96's & kept the stock D-jet injection. (IMG:style_emoticons/default/sunglasses.gif) Yes the 2056. I got the number mixed up - though I find it listed as different values in different tables. Perhaps it is a difference between the english and metric values for pi. Now I have to find the right cam! |
Lo-Fi Version | Time is now: 14th May 2024 - 10:00 AM |
