Seat foam, anyone sell it? |
ruby914 |
Oct 20 2012, 08:56 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
Is there a source for this seat foam?
I have a small block that I was going to scab and reshape, before I do that I thought I should look to see if anyone is reproducing this foam. (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
76-914 |
Oct 20 2012, 09:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Is there a source for this seat foam? I have a small block that I was going to scab and reshape, before I do that I thought I should look to see if anyone is reproducing this foam. (IMG:style_emoticons/default/confused24.gif) Mike, find an wholesale auto upholstery supply. You'll have to buy a larger piece, though. |
ruby914 |
Oct 20 2012, 09:16 PM
Is there a source for this seat foam? I have a small block that I was going to scab and reshape, before I do that I thought I should look to see if anyone is reproducing this foam. (IMG:style_emoticons/default/confused24.gif) Mike, find an wholesale auto upholstery supply. You'll have to buy a larger piece, though. Hi Kent, I have a piece that will do the repair job. But the OEM molded part has a denser outer layer that I felt would hold up better. Maybe, as long as I don't have a hole in the vinyl It will last? |
Lo-Fi Version | Time is now: 26th May 2024 - 06:03 PM |
