> 5-Lug Vented Rotors on Rear, Some Questions
Spoke
post Oct 20 2012, 09:35 PM
Post #21
Jerry
The next project for my 914 is converting to 5-lug suspension. I have the front struts and rear hub from a 1972 911 to start with.
The rear will have vented rotors. I have some questions about doing this part of the conversion.
Two questions:
1) Will I need longer studs in the rear? Before adding the spacer, a lug would catch with 11 rotations on a stud. After adding the spacer, a lug catches with only 8 rotations.
2) When I add the spacer, the rotor is no longer centered perfectly on the hub. How do I center the rotor on the hub?
911 Hub
Hub with spacer
Hub with spacer and rotor. 911 rotor has been cut by Eric Shea. Thanks E.
With the spacer, the lug only catches with 8 revolutions, down from 11 in its stock state. Is this enough or do I need longer studs?
With the spacer, the rotor lip that centers it on the hub now misses the hub because of the spacer. How do I center the rotor now? Do I use just the 2 little hold-on screws to center?
One of the calipers that will be used.
Spoke   5-Lug Vented Rotors on Rear   Oct 20 2012, 09:35 PM
SirAndy   The spacer always goes on after the rotor. Unless ...   Oct 20 2012, 10:33 PM
Black22   The spacer always goes on after the rotor. Unless...   Oct 20 2012, 10:43 PM
Spoke   As far as stud length goes, my guideline is to us...   Oct 21 2012, 10:35 AM
Eric_Shea   This spacer goes under the rotor. It is to make up...   Oct 20 2012, 10:59 PM
bulitt   This is a great kit! Thanks for offering it E...   Oct 21 2012, 04:40 AM
Eric_Shea   944s use 50mm studs. I was thinking the exact sam...   Oct 21 2012, 11:51 AM
Elliot Cannon   944s use 50mm studs. I was thinking the exact sa...   Nov 5 2012, 04:11 PM
Matt Romanowski   944s use 50mm studs. I was thinking the exact sa...   Feb 24 2014, 09:27 AM
Spoke   I did the open lug test and there was about 3/8 in...   Nov 5 2012, 11:25 AM
Cap'n Krusty   The rule of thumb that applies here is "threa...   Nov 5 2012, 12:02 PM
6freak   The rule of thumb that applies here is "thre...   Nov 5 2012, 04:03 PM
Eric_Shea   This is my favorite Elliot: http://www.914world.c...   Nov 5 2012, 07:35 PM
Spoke   I opted to stay with re-drilled 914 hubs instead o...   Nov 18 2012, 06:30 PM
Spoke   I made a couple of spacers out of 10mil brass shee...   Nov 18 2012, 07:26 PM
sixnotfour   wheels can have 1-1.5mm radial runout, lateral is ...   Nov 18 2012, 07:48 PM
Eric_Shea   :agree: For a permenant solution, install the rot...   Nov 18 2012, 08:06 PM
Jeffs9146   :agree: For a permenant solution, install the ro...   Nov 18 2012, 08:41 PM
Spoke   :agree: For a permenant solution, install the ro...   Nov 18 2012, 08:57 PM
Spoke   One more question: Does the spacer assume that a ...   Nov 19 2012, 08:31 AM
Eric_Shea   Yes.   Nov 19 2012, 09:35 AM
Eric_Shea   I'll expound now that I'm not on the iPhon...   Nov 19 2012, 10:16 AM
Spoke   What is a distance washer? I was thinking about c...   Nov 19 2012, 12:19 PM
Spoke   In order to keep the rock shield and not offset th...   Nov 19 2012, 09:38 PM
jim_hoyland   I'm looking at the same issues. Your solution ...   Feb 23 2014, 08:28 AM
Eric_Shea   Jim, In your situation, wouldn't the shield m...   Feb 23 2014, 08:56 AM
Spoke   Jerry, why did you end up grinding the caliper an...   Feb 24 2014, 11:07 AM
jim_hoyland   Jim, In your situation, wouldn't the shield ...   Feb 25 2014, 03:26 PM
Philip W.   Jim, I just did this, they should pull out after...   Feb 25 2014, 07:35 PM
jim_hoyland   [quote name='Philip W.' date='Feb 25 2...   Feb 25 2014, 08:51 PM
jim_hoyland   Thanks Eric, I forgot he used a spacer under the r...   Feb 23 2014, 09:23 AM
Eric_Shea   I wouldn't set the venting clearance until the...   Feb 23 2014, 05:33 PM
Jeff Hail   Are those SC or Carrera rear rotors? Looks like th...   Feb 23 2014, 06:47 PM
Spoke   Are those SC or Carrera rear rotors? Looks like t...   Feb 24 2014, 11:15 AM
Eric_Shea   SC. If the rotor fits the groove the pads should f...   Feb 23 2014, 08:02 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:54 PM
