Which gaskets to replace on head install? |
PDXMike |
Oct 26 2012, 09:03 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
I'm about to install my cylinder heads (I did not remove the cylinders) and I don't want to miss any gaskets. The push rod tubes will get new o-rings, the exhaust ports will get new copper gaskets, and there will be new gaskets between the tops of the cylinders and the heads. What else is there?
Also, I bought a gasket kit, but I'm not sure which gaskets to use at the tops of the cylinders. There are 4 gaskets that look about right shrink-wrapped to cardboard, there are four more in individual bags, and there are four MORE in with some exhaust gaskets. Which are the right ones? Thanks, Mike |
Elliot Cannon |
Oct 26 2012, 10:44 PM
Mark Henry |
Oct 26 2012, 10:47 PM
One crusty guy here uses them, many of us toss them in the bin and don't use any head gaskets.
One of those sets are for the base of the cylinder, the other is the head gasket. |
cary |
Oct 26 2012, 10:57 PM
Run for cover ...............
The shxxs going to fly now........................... I built mine without. I followed a certain persons video. |
euro911 |
Oct 27 2012, 12:34 AM
Anneal the copper exhaust gaskets with a propane or MAP gas torch before installing them (IMG:style_emoticons/default/blowtorch.gif)
Bob L. |
Oct 27 2012, 09:29 AM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Anneal the copper exhaust gaskets with a propane or MAP gas torch before installing them (IMG:style_emoticons/default/blowtorch.gif) I'll be doing those soon. How do you know when they're done? Color change? Sorry for hijack. |
euro911 |
Oct 27 2012, 09:45 AM
Yes. Just soften them up a bit so they'll conform better to any irregularities between the head and the exhaust pipe(s).
It's also a good idea to use some copper paste anti-seize on the exhaust studs/nuts (IMG:style_emoticons/default/idea.gif) |
'73-914kid |
Oct 27 2012, 10:48 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Anneal the copper exhaust gaskets with a propane or MAP gas torch before installing them (IMG:style_emoticons/default/blowtorch.gif) I'll be doing those soon. How do you know when they're done? Color change? Sorry for hijack. Heat until they're, well, nice and hot, quench in water. If annealed correctly, they'll go from a "ping" sound to a "thud" sound when you taps them against pavement or anything metal. |
NORD |
Oct 27 2012, 11:46 AM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
Anneal the copper to redhot careful not to start melting keep the touch moving around evenly. Yes they will thud instead of ting. |
stugray |
Oct 27 2012, 12:08 PM
QUOTE quench in water. My understanding of metallurgy is that you do NOT want to quench them in water. Quenching typically hardens metals. Heating and letting them cool as slowly as possible makes them softer. At least with Steel. Copper I am not as sure. I do NOT use head gaskets. Stu |
dlee6204 |
Oct 27 2012, 12:09 PM
QUOTE My understanding of metallurgy is that you do NOT want to quench them in water. Quenching typically hardens metals. Heating and letting them cool as slowly as possible makes them softer. (IMG:style_emoticons/default/agree.gif) |
edwin |
Oct 27 2012, 05:48 PM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
Copper is the opposite of ferrous metals and quenching will soften
Drums66 |
Oct 27 2012, 06:46 PM
......Some say use them & some say don't?( (IMG:style_emoticons/default/confused24.gif) )
(IMG:style_emoticons/default/bye1.gif)(I don't) |
Bob L. |
Oct 27 2012, 06:52 PM
OK, so I'll try without quenching and see if I get the thud. If not, Then I'll try again with quenching. Will report back in about a week.
Bob L. |
Nov 10 2012, 07:20 PM
Well, I did it. I used a small propane torch and heated them up. I could see a change in the metal where the flame was. I'm a little color blind so I'll leave it at that. It took 5-10 seconds to appear and only lasted while the flame was on it.
As far as the sound changing... a little bit. There was not much "ting" to them to begin with. After I did the first one and let it cool on its own, I compared it with a fresh one by twisting them. Slightly. There was a noticeable difference in the feel of the two gaskets. The annealed one was a lot easier to move. Almost like lead, firm lead. I did the rest the same way. I am happy with them now and see no need for quenching. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:24 AM |
