LSD breakaway torques |
pcar916 |
Oct 31 2012, 01:27 PM
I have enough mileage on the 40/60 LSD to measure the breakaway torque. Now that the Paul Guard is no longer at GT and having talked to Matt for internal rebuild specs, I have a question for those of you who track that specification.
Excellent customer support by Paul before him, and now Matt, on my diff by the way, but Matt has no way of knowing what Paul dialed into my diff when it was assembled, and I can't find where I wrote it down. He questioned me at length about my driving style and how the car was to be used before building the unit. Now, before anyone brings it up I know there are more things involved than simply overcoming the pre-load created by the Belleville washers, like having more or fewer actual clutch plates, so feel free to include those assumptions in your descriptions if needed... what breakaway torques (accel/decel) do you clutch-types build into your diff's in our mid-engined machines? For those who never heard of this the "breakaway torque" is the amount of torque you have to apply to one rear wheel (off the ground) to make it rotate when the other wheel is locked in place and can't turn. The differential has a different number for acceleration than deceleration unless it's setup to the same angle for both directions. |
sixnotfour |
Oct 31 2012, 03:53 PM
914 Wizard Group: Members Posts: 10,414 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Here is a great thread about locking %'s and break away torque and disc packs affecting the torque value.
http://forums.pelicanparts.com/porsche-911...e-modified.html |
pcar916 |
Nov 1 2012, 02:35 PM
Read that thread and it's interesting. My LSD is the ramped type so only a bit of it applies, but some reading of Carol Shelby's thoughts on the subject are good as well. I know there is lots of interest in this topic so it might be that folks are just too competitive to let secrets out into the ether.
Drivers who simply tell their engineers or mechanics how they want the car to handle and leave the details to them won't necessarily know. But for those of us who are one-man driver/mechanics/engineers and the pit crews are friends and family, it's a it more of a process. |
sixnotfour |
Nov 1 2012, 02:58 PM
True, but you asked about break away Torque, You will have to pull the diff to see what ramp angle, accel and deccel. If you dont know,
Here is more about ramps. http://icpcitation.com/variloc_theory.htm https://docs.google.com/viewer?a=v&q=ca...4_E44S4kdlKWbDg |
pcar916 |
Nov 1 2012, 04:23 PM
Good articles and thanks. My ramp angles are 40/60 (accel/decel). I confirmed that when it when disassembled for inspection while in the box to replace the R&P.
I know the higher the preload (and breakaway) the more understeer will be created and the lower it is the more oversteer I'll have. The right amount would be the balance between the two where throttle can be used to modulate between under and oversteer. So my question is pointed to that more than the lockup ratio, even though they both contribute to the handling of the car. |
Richard Casto |
Nov 2 2012, 12:24 PM
Ron,
I am not helping to answer your original question. I would also love to hear some good empirical information, but I suspect that the vast bulk of those who may have an LSD has no idea what their break away torque value is. For those of you who do actually know, please share! (IMG:style_emoticons/default/smile.gif) Anyhow, I typed up this article earlier this year and figured you or others might find it interesting... http://www.blueskymotorsports.com/index.ph...20&Itemid=6 One thing to remember when talking about clutch type LSD is to not confused "ramp angles" and "percent locking/locking factor/anti slip effectiveness". It seems that people tend to mix them up and it generates a lot of confusion. For example a 30 degree ramp angle could result in 40% or 80% locking depending upon clutch pack configuration. Richard |
pcar916 |
Nov 3 2012, 05:27 AM
Richard, outstanding writeup. You are correct that I stated ramp angles when I meant percent lockup on load/overrun. In addition my clutch setup is O l O l on each side. I didn't know to specify that one way or another when I ordered the diff.
So if I want to modify my slip (therefore breakaway torque) I'd rearrange the disc configuration or change the thickness of the entire clutch package to increase/decrease the spring tension. I'd have to contact GT to find out how much the lockup percentage changes when two friction disks (internal spines in my case) are put next to each other, or when one of them is replaced by a smooth disk so only one is present on each side. I know the smooth disks (externally splined) can be ordered in various thicknesses. One disk per side, or reducing the spring tension "some amount" might solve my terminal understeer problem when I attempt to run the occasional AX. I know the AX guys must run a higher slip percentage than the track crowd just to be able to get the cars to turn in. Sounds like multiple gearboxes is the best answer. Of course this isn't a trivial amount of time to spend on tuning. Especially since our (914) gear clusters have to come out before the diff does. Kinda makes me want to invert a 915 so the R&P is beside the side cover. 911 gearboxes are so easy that way. But enough of that ramble. I'm already running synthetic gear oil so I won't get much more slip with fluid changes... and no, I don't go through sychronizers or dog teeth. Thanks for the replies guys. |
Lo-Fi Version | Time is now: 30th April 2024 - 12:42 AM |
