> Rear wheel bearing replacement, Parts needed?
JawjaPorsche
post Nov 14 2012, 01:12 PM
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below)
When I order parts, do I just need the Bearing #28?
Is there a race for the control arm because I don't see one?
Does he need to remove CV axle and tap out the bearing from the inside?
Thank you in advance for your help.
Van914
post Nov 14 2012, 04:38 PM
Van914
Made my own tool using pipe and caps from the Home Depot. Get pipe to contact the outside of the bearng.
Also used a BFH (IMG:style_emoticons/default/smash.gif)
Then I used an extra stub axle to finish.
Just one way
Van914
914itis
post Nov 14 2012, 04:55 PM
QUOTE(Van914 @ Nov 14 2012, 05:38 PM) *
Just one way
Van914
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
JawjaPorsche   Rear wheel bearing replacement   Nov 14 2012, 01:12 PM
Travis Neff   You just need the bearing, its a sealed unit so th...   Nov 14 2012, 01:13 PM
Jeffs9146   Just the bearing! :beer2: You might as well r...   Nov 14 2012, 01:14 PM
Tom_T   Just the bearing! :beer2: You might as well ...   Nov 14 2012, 02:24 PM
DennisV   You might as well replace the bushings also while...   Apr 11 2023, 04:17 PM
Superhawk996   You might as well replace the bushings also whil...   Apr 11 2023, 06:16 PM
SLITS   CV has to be removed, along with caliper and rotor...   Nov 14 2012, 03:01 PM
matthepcat   You will also need a freezer and time to let it fr...   Nov 14 2012, 03:24 PM
JawjaPorsche   I read about the freezer trick earlier and was pla...   Nov 14 2012, 04:25 PM
Jeffs9146   If your mechanic is doing the work then he will ne...   Nov 14 2012, 04:36 PM
JawjaPorsche   I was going to pack it in ice before taking to the...   Nov 14 2012, 04:44 PM
Van914   Made my own tool using pipe and caps from the Home...   Nov 14 2012, 04:38 PM
914itis   Made my own tool using pipe and caps from the Hom...   Nov 14 2012, 04:55 PM
bandjoey   PBM videos on U tube of tear down and install   Nov 14 2012, 05:01 PM
SLITS   PBM videos on U tube of tear down and install P...   Nov 14 2012, 06:25 PM
Jeffs9146   PBM videos on U tube of tear down and install ...   Nov 14 2012, 06:28 PM
76-914   I've done them in the car but next time I...   Nov 14 2012, 08:50 PM
somd914   I had no luck getting a bearing out recently - tri...   Nov 14 2012, 09:57 PM
cwpeden   CV gaskets?   Nov 15 2012, 12:23 AM
Amphicar770   I know this is an old thread but I saw something e...   Feb 9 2016, 08:15 PM
rjames   The correct schnorr washers for the cv bolts for w...   Feb 10 2016, 12:09 AM
veekry9   .......No hammers allowed. ^ Agreed, If a prope...   Feb 10 2016, 12:46 AM
jack20   Hi, Would you mind describing the noise? I have a ...   Feb 10 2016, 07:52 PM
Amphicar770   I chilled the bearing and then started it with a r...   Feb 13 2016, 09:50 AM
rjames   No need to replace the bushings if you're leav...   Apr 12 2023, 10:04 AM
neilbardsley   This job was done on my car recently and the mecha...   Jun 10 2024, 05:32 AM
930cabman   This job was done on my car recently and the mech...   Jun 10 2024, 07:39 AM
neilbardsley   Yes he completed the job. I was just a bit surpri...   Jun 11 2024, 06:41 AM
rjames   Yes he completed the job. I was just a bit surpr...   Jun 11 2024, 10:19 AM
930cabman   I changed both awhile ago, had the bearings packed...   Jun 11 2024, 02:42 PM
jim_hoyland   What’s the life expectancy for a rear bearing ? ...   Jun 13 2024, 09:54 AM
Superhawk996   What’s the life expectancy for a rear bearing ?...   Jun 13 2024, 11:51 AM
jim_hoyland   Thanks; good info to know… :)   Jun 13 2024, 12:06 PM
- Lo-Fi Version Time is now: 7th March 2026 - 10:34 PM
