| JawjaPorsche |
Nov 14 2012, 01:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below) When I order parts, do I just need the Bearing #28? Is there a race for the control arm because I don't see one? Does he need to remove CV axle and tap out the bearing from the inside? Thank you in advance for your help. Attached thumbnail(s) |
| cwpeden |
Nov 15 2012, 12:23 AM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
CV gaskets?
JawjaPorsche Rear wheel bearing replacement Nov 14 2012, 01:12 PM
Travis Neff You just need the bearing, its a sealed unit so th... Nov 14 2012, 01:13 PM
Jeffs9146 Just the bearing! :beer2:
You might as well r... Nov 14 2012, 01:14 PM
Tom_T
You might as well ... Nov 14 2012, 02:24 PM
DennisV
You might as well replace the bushings also while... Apr 11 2023, 04:17 PM
Superhawk996
You might as well replace the bushings also whil... Apr 11 2023, 06:16 PM
SLITS CV has to be removed, along with caliper and rotor... Nov 14 2012, 03:01 PM
matthepcat You will also need a freezer and time to let it fr... Nov 14 2012, 03:24 PM
JawjaPorsche I read about the freezer trick earlier and was pla... Nov 14 2012, 04:25 PM
Jeffs9146 If your mechanic is doing the work then he will ne... Nov 14 2012, 04:36 PM
JawjaPorsche I was going to pack it in ice before taking to the... Nov 14 2012, 04:44 PM
Van914 Made my own tool using pipe and caps from the Home... Nov 14 2012, 04:38 PM
914itis
Made my own tool using pipe and caps from the Hom... Nov 14 2012, 04:55 PM
bandjoey PBM videos on U tube of tear down and install Nov 14 2012, 05:01 PM
SLITS
P... Nov 14 2012, 06:25 PM
Jeffs9146
... Nov 14 2012, 06:28 PM
76-914 I've done them in the car but next time I... Nov 14 2012, 08:50 PM
somd914 I had no luck getting a bearing out recently - tri... Nov 14 2012, 09:57 PM
Amphicar770 I know this is an old thread but I saw something e... Feb 9 2016, 08:15 PM
rjames The correct schnorr washers for the cv bolts for w... Feb 10 2016, 12:09 AM
veekry9
.......No hammers allowed.
Agreed,
If a prope... Feb 10 2016, 12:46 AM
jack20 Hi,
Would you mind describing the noise?
I have a ... Feb 10 2016, 07:52 PM
Amphicar770 I chilled the bearing and then started it with a r... Feb 13 2016, 09:50 AM
rjames No need to replace the bushings if you're leav... Apr 12 2023, 10:04 AM
neilbardsley This job was done on my car recently and the mecha... Jun 10 2024, 05:32 AM
930cabman
This job was done on my car recently and the mech... Jun 10 2024, 07:39 AM
neilbardsley Yes he completed the job. I was just a bit surpri... Jun 11 2024, 06:41 AM
rjames
Yes he completed the job. I was just a bit surpr... Jun 11 2024, 10:19 AM
930cabman I changed both awhile ago, had the bearings packed... Jun 11 2024, 02:42 PM
jim_hoyland What’s the life expectancy for a rear bearing ?
... Jun 13 2024, 09:54 AM
Superhawk996
What’s the life expectancy for a rear bearing ?... Jun 13 2024, 11:51 AM
jim_hoyland Thanks; good info to know… :) Jun 13 2024, 12:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 09:45 PM |
