> Rear wheel bearing replacement, Parts needed?
JawjaPorsche
post Nov 14 2012, 01:12 PM
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below)
When I order parts, do I just need the Bearing #28?
Is there a race for the control arm because I don't see one?
Does he need to remove CV axle and tap out the bearing from the inside?
Thank you in advance for your help.
Jeffs9146
post Nov 14 2012, 01:14 PM
Ski Bum
Just the bearing! (IMG:style_emoticons/default/beerchug.gif)
You might as well replace the bushings also while your in there!!
DennisV
post Apr 11 2023, 04:17 PM
QUOTE(Jeffs9146 @ Nov 14 2012, 12:14 PM) *
Can you please clarifying "bushings"? I'm sure it's obvious to someone with experience, but it's not to me. There's nothing in the diagram called "bushing". Thank you.
JawjaPorsche   Rear wheel bearing replacement   Nov 14 2012, 01:12 PM
Travis Neff   You just need the bearing, its a sealed unit so th...   Nov 14 2012, 01:13 PM
Jeffs9146   Just the bearing! :beer2: You might as well r...   Nov 14 2012, 01:14 PM
Tom_T   Just the bearing! :beer2: You might as well ...   Nov 14 2012, 02:24 PM
DennisV   You might as well replace the bushings also while...   Apr 11 2023, 04:17 PM
Superhawk996   You might as well replace the bushings also whil...   Apr 11 2023, 06:16 PM
SLITS   CV has to be removed, along with caliper and rotor...   Nov 14 2012, 03:01 PM
matthepcat   You will also need a freezer and time to let it fr...   Nov 14 2012, 03:24 PM
JawjaPorsche   I read about the freezer trick earlier and was pla...   Nov 14 2012, 04:25 PM
Jeffs9146   If your mechanic is doing the work then he will ne...   Nov 14 2012, 04:36 PM
JawjaPorsche   I was going to pack it in ice before taking to the...   Nov 14 2012, 04:44 PM
Van914   Made my own tool using pipe and caps from the Home...   Nov 14 2012, 04:38 PM
914itis   Made my own tool using pipe and caps from the Hom...   Nov 14 2012, 04:55 PM
bandjoey   PBM videos on U tube of tear down and install   Nov 14 2012, 05:01 PM
SLITS   PBM videos on U tube of tear down and install P...   Nov 14 2012, 06:25 PM
Jeffs9146   PBM videos on U tube of tear down and install ...   Nov 14 2012, 06:28 PM
76-914   I've done them in the car but next time I...   Nov 14 2012, 08:50 PM
somd914   I had no luck getting a bearing out recently - tri...   Nov 14 2012, 09:57 PM
cwpeden   CV gaskets?   Nov 15 2012, 12:23 AM
Amphicar770   I know this is an old thread but I saw something e...   Feb 9 2016, 08:15 PM
rjames   The correct schnorr washers for the cv bolts for w...   Feb 10 2016, 12:09 AM
veekry9   .......No hammers allowed. ^ Agreed, If a prope...   Feb 10 2016, 12:46 AM
jack20   Hi, Would you mind describing the noise? I have a ...   Feb 10 2016, 07:52 PM
Amphicar770   I chilled the bearing and then started it with a r...   Feb 13 2016, 09:50 AM
rjames   No need to replace the bushings if you're leav...   Apr 12 2023, 10:04 AM
neilbardsley   This job was done on my car recently and the mecha...   Jun 10 2024, 05:32 AM
930cabman   This job was done on my car recently and the mech...   Jun 10 2024, 07:39 AM
neilbardsley   Yes he completed the job. I was just a bit surpri...   Jun 11 2024, 06:41 AM
rjames   Yes he completed the job. I was just a bit surpr...   Jun 11 2024, 10:19 AM
930cabman   I changed both awhile ago, had the bearings packed...   Jun 11 2024, 02:42 PM
jim_hoyland   What’s the life expectancy for a rear bearing ? ...   Jun 13 2024, 09:54 AM
Superhawk996   What’s the life expectancy for a rear bearing ?...   Jun 13 2024, 11:51 AM
jim_hoyland   Thanks; good info to know… :)   Jun 13 2024, 12:06 PM
- Lo-Fi Version Time is now: 7th March 2026 - 09:53 PM
