| JawjaPorsche |
Nov 14 2012, 01:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My right rear bearing is making noises. I called my mechanic and he said to get parts and he would install it.
I am looking at the exploded view of rear axle. (See below) When I order parts, do I just need the Bearing #28? Is there a race for the control arm because I don't see one? Does he need to remove CV axle and tap out the bearing from the inside? Thank you in advance for your help. Attached thumbnail(s) |
| neilbardsley |
Jun 10 2024, 05:32 AM
Newbie ![]() Group: Members Posts: 44 Joined: 11-October 20 From: England Member No.: 24,754 Region Association: Europe |
This job was done on my car recently and the mechanic said he had to drop the exhaust to get the drive shaft out to change the rear wheel bearing?
JawjaPorsche Rear wheel bearing replacement Nov 14 2012, 01:12 PM
Travis Neff You just need the bearing, its a sealed unit so th... Nov 14 2012, 01:13 PM
Jeffs9146 Just the bearing! :beer2:
You might as well r... Nov 14 2012, 01:14 PM
Tom_T
You might as well ... Nov 14 2012, 02:24 PM
DennisV
You might as well replace the bushings also while... Apr 11 2023, 04:17 PM
Superhawk996
You might as well replace the bushings also whil... Apr 11 2023, 06:16 PM
SLITS CV has to be removed, along with caliper and rotor... Nov 14 2012, 03:01 PM
matthepcat You will also need a freezer and time to let it fr... Nov 14 2012, 03:24 PM
JawjaPorsche I read about the freezer trick earlier and was pla... Nov 14 2012, 04:25 PM
Jeffs9146 If your mechanic is doing the work then he will ne... Nov 14 2012, 04:36 PM
JawjaPorsche I was going to pack it in ice before taking to the... Nov 14 2012, 04:44 PM
Van914 Made my own tool using pipe and caps from the Home... Nov 14 2012, 04:38 PM
914itis
Made my own tool using pipe and caps from the Hom... Nov 14 2012, 04:55 PM
bandjoey PBM videos on U tube of tear down and install Nov 14 2012, 05:01 PM
SLITS
P... Nov 14 2012, 06:25 PM
Jeffs9146
... Nov 14 2012, 06:28 PM
76-914 I've done them in the car but next time I... Nov 14 2012, 08:50 PM
somd914 I had no luck getting a bearing out recently - tri... Nov 14 2012, 09:57 PM
cwpeden CV gaskets? Nov 15 2012, 12:23 AM
Amphicar770 I know this is an old thread but I saw something e... Feb 9 2016, 08:15 PM
rjames The correct schnorr washers for the cv bolts for w... Feb 10 2016, 12:09 AM
veekry9
.......No hammers allowed.
Agreed,
If a prope... Feb 10 2016, 12:46 AM
jack20 Hi,
Would you mind describing the noise?
I have a ... Feb 10 2016, 07:52 PM
Amphicar770 I chilled the bearing and then started it with a r... Feb 13 2016, 09:50 AM
rjames No need to replace the bushings if you're leav... Apr 12 2023, 10:04 AM
930cabman
This job was done on my car recently and the mech... Jun 10 2024, 07:39 AM
neilbardsley Yes he completed the job. I was just a bit surpri... Jun 11 2024, 06:41 AM
rjames
Yes he completed the job. I was just a bit surpr... Jun 11 2024, 10:19 AM
930cabman I changed both awhile ago, had the bearings packed... Jun 11 2024, 02:42 PM
jim_hoyland What’s the life expectancy for a rear bearing ?
... Jun 13 2024, 09:54 AM
Superhawk996
What’s the life expectancy for a rear bearing ?... Jun 13 2024, 11:51 AM
jim_hoyland Thanks; good info to know… :) Jun 13 2024, 12:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 10:31 PM |
