PCV Valve, When to replace, where to get |
ThinAir |
Nov 3 2004, 10:06 PM
Best friends Group: Members Posts: 2,531 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
How do you tell when your PCV valve needs replacement?
If you need one, where do you get it and about how much? I've checked Pelican and GPR, but can't find one. I haven't called Brad yet, but I know he can get anything. I'm just curious how much they cost. They aren't much for a Honda at my FLAPS, but I doubt they would have one for a 914. |
McMark |
Nov 4 2004, 04:07 AM
From the dealer. Who's got the part number?
pbanders |
Nov 4 2004, 07:25 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
ThinAir |
Nov 4 2004, 09:57 AM
Thanks, Brad! That is great information. In all the years that I've had a 914, I've never done anything with the PCVV, except hook the breather hose up to it. On other cars it's always part of the maintenance routine, but for some reason I've never thought about it before as far as my Type IV is concerned.
The reason I asked about this is because I'm starting to assemble my 2.0L D-Jet. I want this to be an absolutely dry engine. One of the most often cited causes for the seep of oil from a Type IV engine is pressure within the crankcase, so it occured to me that if the PCV valve was not operating correctly, it could be part of why a Type IV leaks oil. So is there an "engine breathing unit" that would be a good thing to put onto a Type IV to replace the stock PCV valve? You see a lot of these kinds of units on VWs, especially Type I engines, but these are almost always carbureted engines. Brad's helpful page makes it look like it's really no big deal to maintain or replace the stock valve, but I'm just wondering if there is a better way to go. |
SLITS |
Nov 4 2004, 10:03 AM
If you could make it fit into the oil filler assembly, most any PCV valve would work IMO.
And also remember you have the AFB valve which is also venting crankcase pressure via suction to the aircleaner. |
ThinAir |
Nov 4 2004, 10:21 AM
QUOTE(SLITS @ Nov 4 2004, 09:03 AM) ...the AFB valve... The what? What is this and where is it? (I probably should go look at Brand Anders pages before I ask this.) |
Nov 4 2004, 05:33 PM
I just got a PCV valve from Pelican. It's not in the catalog, but it is available. Some of the associated bits are not, though.
--DD |
ThinAir |
Nov 4 2004, 08:11 PM
Thanks Dave. So what's an AFB valve? |
pbanders |
Nov 5 2004, 09:40 AM
AFB = Anti-flashback. If I recall correctly, it's not a "valve", but a metal can filled with mesh that is connected through a hose on one side to the air box, and "tees" off on the other side to the heads. It's designed to stop backfire flame fronts from propagating to the heads, where the flame could ignite combustible gasses in the crankcase.
I just took a look in the factory workshop manual. Porsche also calls it a valve, but there is no valving mechanism inside of it that I'm aware of. The crankcase ventilation system functioning is described on the web page I referenced in an earlier posting. |
ctc911ctc |
Apr 2 2019, 04:09 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
ANYONE have a source for PVC valves? Mine is mighty leaky.
914Sixer |
Apr 3 2019, 07:22 AM
914 Guru Group: Members Posts: 8,869 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
No replacements that I know of. 022 115 542. Might check with George at AutoAtlanta.
dr914@autoatlanta.com |
Apr 3 2019, 08:35 AM
914 Guru Group: Members Posts: 7,816 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
should be able to clean yours and as long as it does not leak be all set, it simply unscrews from the oil filler housing.
We have new ones but they are expensive How do you tell when your PCV valve needs replacement? If you need one, where do you get it and about how much? I've checked Pelican and GPR, but can't find one. I haven't called Brad yet, but I know he can get anything. I'm just curious how much they cost. They aren't much for a Honda at my FLAPS, but I doubt they would have one for a 914. |
Not_A_Six |
Oct 19 2019, 08:32 PM
Member Group: Members Posts: 110 Joined: 28-November 18 From: North Idaho Member No.: 22,682 Region Association: Pacific Northwest |
should be able to clean yours and as long as it does not leak be all set, it simply unscrews from the oil filler housing. We have new ones but they are expensive I tried cleaning it, but I think mine is sticking and/or worn and messing up my idle. I tried to order one from AA, but it looks like they're out of stock and they are NLA. Anybody got a current source for a PCV valve? Thanks. |
914Sixer |
Oct 20 2019, 07:50 AM
Let it soak in some parts cleaner or PB blaster for a day or so then see what happens. You should be able to hear cylinder going back and forth when you shake it.
Not_A_Six |
Oct 20 2019, 05:28 PM
Let it soak in some parts cleaner or PB blaster for a day or so then see what happens. You should be able to hear cylinder going back and forth when you shake it. Thanks. I'll try cleaning it again. Does a 914 PCV valve rattle like a modern one? Mine does not, but I thought that was normal because the spring inside keeps the plunger closed except when under vacuum... (IMG:style_emoticons/default/confused24.gif) |
914Sixer |
Oct 20 2019, 06:28 PM
Don't think I have ever seen a spring one. I will check the one in the warehouse later in the week.
bdstone914 |
Oct 20 2019, 06:46 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
bdstone914 |
Oct 20 2019, 06:49 PM
@Not_A_Six date='Oct 19 2019, 07:32 PM' post='2755826']
[quote name='dr914@autoatlanta.com' post='2702189' date='Apr 3 2019, 07:35 AM'] should be able to clean yours and as long as it does not leak be all set, it simply unscrews from the oil filler housing. We have new ones but they are expensive [/quote] I tried cleaning it, but I think mine is sticking and/or worn and messing up my idle. I tried to order one from AA, but it looks like they're out of stock and they are NLA. Anybody got a current source for a PCV valve? Thanks. [/quote] I have cleaned and replated ones for $25 shipped. Bruce |
Not_A_Six |
Oct 20 2019, 06:59 PM
Not_A_Six |
Nov 4 2019, 11:23 PM
I have cleaned and replated ones for $25 shipped. Bruce Awesome! Thanks! I sent you a message to set up the order. How do you "replate" them? The case looks like it can't be opened... @bdstone914 Well, I understand now what you mean by "replated". I got a shiny yellow-zinc-(re)plated anti-flashback valve in the mail today. Thanks. It looks beautiful. (IMG:style_emoticons/default/smile.gif) Unfortunately, what I needed is a PCV valve. (IMG:style_emoticons/default/sad.gif) So far, I'm 0 for 2 with this part. Anybody have a current source for a PCV valve for a '73 2.0? Thanks. |
Lo-Fi Version | Time is now: 24th April 2024 - 03:39 PM |
