What are you guys putting under your Carpet? |
Kerrys914 |
May 15 2003, 06:07 AM
What type of under pad are you putting under your 914's carpet.
Does the foil backed stuff from JC's work? I would like something that will not soak up water like a sponge. Cheers Kerry |
Red-Beard |
May 15 2003, 06:54 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
I guess drugs would be the obvious answer....
I used a vibration dampening mat. It's very heavy. I also used it on the firewall and under the seats and on the front trunk and rear trunk floors. It definitely cut the sound down. McMaster-Carr - Do a search on Vibration and select Vibration Control Compounds. http://www.mcmaster.com/ I got the cheapest one. I also bought a 5 gallon pail of the paint stuff to use inside the doors and the wheel wells, but haven't done it yet. I figure I've added 50 lbs to the car.... James |
Lawrence |
May 15 2003, 07:22 AM
Take a quick visit to your local auto body supply store.
They usually have several flavors of sound-proofing available, and you can choose one that you like best. -Rusty |
aufaber |
May 15 2003, 11:03 AM
Member Group: Members Posts: 190 Joined: 7-April 03 From: Huntington Beach, CA Member No.: 525 |
mskala |
May 15 2003, 01:56 PM
I didn't put anything under mine when it went back in after rust removal.
Right now there's a big discussion of several sound deadening products over on the 911 pelican list. Mark S. '70 914-6 |
Dave Cawdrey |
May 15 2003, 03:03 PM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Use Jute. Dont glue it all, just the coners. If it gets wet, replace it. Less exspensive...
Aaron Cox |
May 15 2003, 04:51 PM
im ready to do carpet also.
i have bare floor pans showing (not bare- painted). tweeks sells "914 floor matt" stuff thta goes under carpet for like 59 bucks. what is it? |
Lo-Fi Version | Time is now: 20th May 2024 - 03:17 AM |
