More fun stuff to do - wheel bearings?, Not sure what kind of sound they make when going bad |
jls914 |
Nov 19 2012, 10:16 PM
Newbie Group: Members Posts: 8 Joined: 23-August 12 From: wendell, NC Member No.: 14,842 Region Association: None |
My left rear made a whining noise and would change when turning. There was also a very noticably heat difference of the two rear wheels. You didn't have to touch them to feel the difference. I changed them both at the same time. I did mine with the trailing arms still mounted on the car.
That's my experience. Jim |
no1uno |
Nov 19 2012, 10:23 PM
Member Group: Members Posts: 206 Joined: 2-December 10 From: Melbourne, FL Member No.: 12,448 Region Association: South East States |
Do you hear the noise when your wife is in the car with you? (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/biggrin.gif) Good One! |
Rockaria |
Nov 20 2012, 10:24 AM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
I have almost this exact same issue. Left rear wheel. Starts whining at 30mph, no grummbling noise or feel, seems to keep the same pitch, a constant rotating whining like metal contacting, goes away instantly under 30 mph. won't go away by turning the car or pressing in the clutch, taking it out of gear. Tranny is perfect and is full of new fluid. The wheel feels solid when I jack up the tire and try to move it around.
But I have found, mine only happens when the weather is hot, like 90 degrees outside. When the weather is cool, it never whines or makes noise at all. Though I do take short trips, less than 50 miles at a time. |
ThePaintedMan |
Dec 5 2012, 10:32 AM
I have almost this exact same issue. Left rear wheel. Starts whining at 30mph, no grummbling noise or feel, seems to keep the same pitch, a constant rotating whining like metal contacting, goes away instantly under 30 mph. won't go away by turning the car or pressing in the clutch, taking it out of gear. Tranny is perfect and is full of new fluid. The wheel feels solid when I jack up the tire and try to move it around. But I have found, mine only happens when the weather is hot, like 90 degrees outside. When the weather is cool, it never whines or makes noise at all. Though I do take short trips, less than 50 miles at a time. Excellent, thanks for the input Chris. My situation sounds the exact same, except opposite. It only started doing this about a month ago when temperatures dropped. It usually doesn't start for the first few miles, but then gradually comes in as (ostensibly) the bearings begin to warm up. At this point I think its a safe bet to start with replacing the bearings - they may very well be the originals anyway. Here is the audio. Sorry for the quality or lack thereof. I think the sound is still audible though. -George |
Spoke |
Dec 5 2012, 11:21 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I had a similar issue after changing the rear of my 914 to 5-lug. Even seemed to change when turning. Didn't start making noise until I drove a bit.
Turns out it was the rear brake venting clearance. When the noise was happening, I touch the brakes and it changed. Adjusted the venting clearance and the noise went away. |
bulitt |
Dec 5 2012, 02:07 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
What kind of fluid are you running in your trans? I ran a Mobil 1 synthetic once in an older transaxle thinkin it was better. The trans was a whiner until I put the original spec stuff in.
bandjoey |
Dec 5 2012, 02:51 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Warped rotor or venting but my brakes are tire and set with no drag. Whine is sorta comforting n a long trip though. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 3rd June 2024 - 08:06 AM |
