Key Questions |
Key Questions |
Tom73 |
Nov 4 2004, 12:47 PM
Member Group: Members Posts: 180 Joined: 20-September 04 From: Central Texas Member No.: 2,792 |
I think that my recently acquired '71 has had keys swaped out in the past. My understanding is that one key will work the ignition, doors, and front & rear trunks. Then the second key, the valet key, will work the doors and ignition only. Right?
My car came with two keys. One looks like a VW key (the hockeystick shape) and it works the ignition. It will not fit it the door/trunk locks. Then I have a large headed key that fits the doors and rear trunk. It will not fit into the ignition. Neither will fit the front trunk lock. Sounds as if the ignition key/cylinder may have been replaced in the past. But what confuses me is that the door key will not even slide into the ignition cylinder. I would like to get this sorted out and back to close to original. Suggestions? tom... |
TheCabinetmaker |
Nov 4 2004, 01:28 PM
Ignition swith has been replaced with a vw (1/4th the price). Door handles have been replaced and had new cylinders. Replace the ignition with a 914, remove all lock cylinders, and take them to a locksmith. He can rekey them to all be the same.
Root_Werks |
Nov 4 2004, 03:02 PM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Yep, just pull them all out and take them into a locksmith. I have had to do it a couple of times. But nice to have the keys working like they should. (IMG:style_emoticons/default/wink.gif)
Nov 4 2004, 05:22 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
...Or check the Pelican tech article on re-keying Porsche locks...
--DD |
Tom73 |
Nov 4 2004, 05:26 PM
QUOTE(vsg914 @ Nov 4 2004, 11:28 AM) Ignition swith has been replaced with a vw (1/4th the price). Door handles have been replaced and had new cylinders. Replace the ignition with a 914, remove all lock cylinders, and take them to a locksmith. He can rekey them to all be the same. Sounds like a plan. May just get a new 914 ignition switch and then have it rekeyed to match the door key. May be a bit cheaper and easier that way. Then get the front trunk lock rekeyed to match. Only have to have two rekeyed that way (IMG:style_emoticons/default/biggrin.gif) Thanks tom... |
TheCabinetmaker |
Nov 4 2004, 07:37 PM
Dave is correct as always. You can rekey them your self.
TheCabinetmaker |
Nov 4 2004, 07:41 PM
Thread hijack!!!!!
Dave, ya got those MUSR pics posted yet? Hijack over! |
Lo-Fi Version | Time is now: 7th May 2024 - 01:55 AM |
