Im new! Fixing up original 914 1.7 1970-1, Its yellow |
dtpten |
Dec 4 2013, 01:22 AM
Newbie Group: Members Posts: 38 Joined: 26-November 12 From: San Jose / Sacramento Member No.: 15,197 Region Association: Northern California |
Cant wait to head back to sacramento to get wrenching again!
trojanhorsepower |
Dec 4 2013, 08:26 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Man that looks great!
dtpten |
Oct 9 2014, 02:44 PM
Hello, Im back and with a couple new pics.
Steering wheel sewing and new home location for now. (IMG:http://www.914world.com/bbs2/uploads_offsite/imagizer.imageshack.us-15197-1412887480.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imagizer.imageshack.us-15197-1412887480.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imagizer.imageshack.us-15197-1412887480.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/imagizer.imageshack.us-15197-1412887480.4.jpg) |
EdwardBlume |
Oct 10 2014, 07:15 AM
Welcome back. Are you driving it? Being your Dad's car, your should keep it.
arkitect |
Oct 11 2014, 06:54 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Brian,
Great looking repairs you and your buddy did. (IMG:style_emoticons/default/beerchug.gif) How's it running now? Did you decide to keep it? Dave |
malcolm2 |
Oct 11 2014, 07:58 AM
Advanced Member Group: Members Posts: 2,729 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Great job so far. Keep it up. Maybe once you drive it, you'll keep it??? (IMG:style_emoticons/default/piratenanner.gif)
(IMG:style_emoticons/default/welcome.png) |
dtpten |
Oct 13 2014, 12:15 PM
runs on starting fluid, having a bad pump or pump is not running because of electrical contacts..?
dtpten |
Oct 16 2014, 06:05 PM
ahh, finally remembered to get the VIN number
4712907960 |
dtpten |
Oct 21 2014, 04:39 PM
just came into the registration month and went to AAA to pay dmv fee and hagerty insurance. All set there (IMG:style_emoticons/default/smile.gif)
Now just need to order that fuel pump and brake calipers. |
dtpten |
Oct 23 2014, 06:30 PM
hopefully removing front air dam for repairs tonight, also removal of door sill sheet metal for repainting. Must i buy new rivets, the 6 on each side?
thanks for any input -B |
dtpten |
Oct 24 2014, 03:52 PM
ok i removed the passenger side door sill but having two rusted cheese head screws on drivers side causing a headache. will using pb blaster then an impact driver to loosens those this weekend.
also i will need to raise the car up high to get the front airdam off because i cant get an arm or see what holding it on there -B |
dtpten |
May 11 2015, 03:41 PM
had a bad ignition switch, found pricey replacement, then to broke the 12 pin plastic connector that attaches inside the dash for ignition/turn signal terminal. On hold until i glue or find a replacement connector.
dtpten |
May 18 2015, 04:49 PM
going the fix it myself , glue it back together and make a mold and pour resin route.
dtpten |
Jun 10 2016, 10:34 AM
Update! I had bad relay board, and 3 bad injectors but all replaced now.
The car started on second key turn and idles smooth. I changed the master cylinder and will be bleeding rear and front brakes in the next couple days. I need to adjust the clutch, was having problems into first and reverse. Yay for me! side note, i did take the car out for a slow drive on a quiet street. |
Jun 10 2016, 11:38 AM
Resident German Group: Admin Posts: 41,581 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
side note, i did take the car out for a slow drive on a quiet street. (IMG:style_emoticons/default/thumb3d.gif) |
914_teener |
Jun 10 2016, 12:43 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Update! I had bad relay board, and 3 bad injectors but all replaced now. The car started on second key turn and idles smooth. I changed the master cylinder and will be bleeding rear and front brakes in the next couple days. I need to adjust the clutch, was having problems into first and reverse. Yay for me! side note, i did take the car out for a slow drive on a quiet street. Great story! Hope you keep the car. Sounds like you might want to check the condition of the shift bushings. Easy to do. |
Lo-Fi Version | Time is now: 29th March 2024 - 08:07 AM |
