waking from slumber, sitting 10yr |
vitaminC |
Nov 29 2012, 03:01 PM
searching... Group: Members Posts: 48 Joined: 29-August 10 From: NorCal Member No.: 12,121 Region Association: Northern California |
So I'm still looking for a car, and I found a '73 1.7 nearby, and the seller is asking $3k. Haven't seen it in person yet, but will try to this weekend. He states clutch and brake work before parked, and "no rust" (but that of course must be verified). What needs to be done to prep a car like this to run again? I'm guessing oil, battery, brake fluid at the minimum. Presuming there really is no rust, how reasonable is the price?
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.craigslist.org-12121-1354222861.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.craigslist.org-12121-1354222861.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.craigslist.org-12121-1354222862.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.craigslist.org-12121-1354222862.4.jpg) Thanks for the help and advice! (IMG:style_emoticons/default/beerchug.gif) |
TravisNeff |
Nov 29 2012, 03:10 PM
From the surface it looks like an attractive buy. Rust repairs can cost a lot, as does engine/transmissions issues.
I would replace battery, gas and oil plus basic tune up parts and see how it goes! |
JawjaPorsche |
Nov 29 2012, 03:24 PM
Check you fuel lines because they last thing you want is a fire!
pete000 |
Nov 29 2012, 03:32 PM
Nice Find !
If it spent all that time out in the yard check for rodent damage. (IMG:style_emoticons/default/driving-girl.gif) |
vitaminC |
Nov 29 2012, 03:54 PM
Thanks for the tips! No doubt the gas has definitely gone bad by now. Also trying to find out why it was parked in the first place...
Hammy |
Nov 29 2012, 07:31 PM
Looks nice from outside, how's the interior? Definitely gas, oil, brake fluid, fuel lines, fuel hoses, rubber brake hoses, battery, probably FI vacuum hoses. How long has it been sitting? Also member above mentioned about rodents may have entered.
They always have rust. |
Hammy |
Nov 29 2012, 07:32 PM
I'm also noticing windshield panel vinyl, this usually indicates a one of first 1000 914's from '73..?
vitaminC |
Nov 29 2012, 08:13 PM
I'm also noticing windshield panel vinyl, this usually indicates a one of first 1000 914's from '73..? Yeah, I noticed the vinyl as well. Cool. I'm still waiting to actually hear from the seller. It's been FS for a while, so I presume it's not gone yet, esp as the ad was just posted a couple of days ago. |
hot_shoe914 |
Nov 29 2012, 09:47 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
If it has been sitting in that grass for 10 years it HAS rust!
ScoopLV |
Nov 30 2012, 02:13 AM
Senior Member Group: Members Posts: 545 Joined: 7-September 12 From: Las Vegas Member No.: 14,897 Region Association: Southwest Region |
If it has been sitting in that grass for 10 years it HAS rust! My thoughts exactly. It's not like this car has been sitting in a desert environment for the past decade. Check the rockers, hellhole, trunks, around the lights, all the usual suspects. I'd plan on dropping the engine immediately and replacing everything that was made out of rubber. Whatever gasoline remains in the car has turned to varnish -- and clogged the injectors and everything else. So you won't be able to start the car, I'll bet. You can at least push the clutch in and see how much play you have. |
watsonrx13 |
Dec 1 2012, 07:26 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
If it has been sitting in that grass for 10 years it HAS rust! Also find out why it was parked, then decide if the price is right. Check for rust in the 'hell hole' (underneath the battery tray), also the firewall/floor behind the seats and see if you can have him remove the rocker panels. If the right rear suspension is at an awkard angle, you will also have problems/rust/issues with the RR suspension ear. Good luck and keep us informed with what you find out about the car. More pics.. --- Rob |
vitaminC |
Dec 1 2012, 05:24 PM
Okay, finally heard back from the seller, and he sent along some more pictures taken today (in the rain): early '73 914 pics
Trying to set up a time to see the car in person next week when it's a bit drier out. Looks like he has a quite a collection of cars returning to the earth. Anyway, this one looks like it may have some rust bubbles at the base of the windshield- or it could be pooled water. Also, is that some sort of aftermarket AC below the dash? He says the odo currently reads 70k. Lots of dead hoses in the engine bay... From my untrained eye, it still looks pretty decent at the price point. Am I missing anything? Really appreciate all the input so far! (IMG:style_emoticons/default/beer.gif) |
IanS |
Dec 1 2012, 06:07 PM
Member Group: Members Posts: 83 Joined: 27-February 12 From: Edmond, Oklahoma Member No.: 14,190 Region Association: Southwest Region |
The good news is the motor is pretty original looking, and the car looks to be all there. It has air conditioning - not sure if you want that or not, the front trunk will have a hole in it where air can get to the A/C parts. Hard to tell if it's ever been in an accident from the pics but it looks pretty straight.
The bad news is he did not show any pics of the typical rust spots! The rear of the rear trunk, the hell hole under the battery in the engine bay as previously mentioned, under the front trunk floorboard, the side rocker panels, places like that. On all the cars I've seen from moist climates the rockers and hell hole are really bad. That stuff is pretty repairable. The A/C adds a lot of complication. The entry price seems reasonable but you are really loking at a lot of potential and likely things to fix. Do you have a total budget in mind? (cause you're gonna go over it if you stay on this site hahaha) |
vitaminC |
Dec 1 2012, 06:56 PM
Do you have a total budget in mind? (cause you're gonna go over it if you stay on this site hahaha) Yeah, probably it would be smarter to start with a car that someone else has already done the work on. There are just not a lot of local options right now, and I'm hesitant to buy something without seeing it in person. My main plans for the car are to use it for AX and DE. I suppose something like this would make a lot more sense (and $) considering my plans. Back to this one, what about picking up a used 2.0L and dropping it in- easy to do? Are those engines easy/inexpensive to find? |
steuspeed |
Dec 1 2012, 08:58 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
I would say 2k, maybe 2.5K tops. That car is going to need love around every corner. I see a clutch and brake caliper in the pasenger well. That's not a good sign. Unless you love it or can get it really cheap, I would try and find a cleaner car that actually runs.
ScoopLV |
Dec 2 2012, 02:45 PM
Do you have a total budget in mind? (cause you're gonna go over it if you stay on this site hahaha) Yeah, probably it would be smarter to start with a car that someone else has already done the work on. There are just not a lot of local options right now, and I'm hesitant to buy something without seeing it in person. There are many, many people on this forum who I would trust to check out a 914 in their area and give me a "thumbs up/thumbs down" on the potential purchase. Start scouring Craigslist in the southwest and see if you find anything. Then post a "can anyone in Phoenix check out a car for me" request. |
Hammy |
Dec 2 2012, 05:11 PM
I would say 2k, maybe 2.5K tops. That car is going to need love around every corner. I see a clutch and brake caliper in the pasenger well. That's not a good sign. Unless you love it or can get it really cheap, I would try and find a cleaner car that actually runs. (IMG:style_emoticons/default/agree.gif) As others have stated, It looks fairly complete which is good, but the parts seem to be everywhere and it takes a lot of time (and $) going through the entire car fixing everything you find. Rust is still the biggest issue. It's definitely not a good sign if it's been sitting in that yard a long while, uncovered. Never know til ya look (IMG:style_emoticons/default/confused24.gif) |
JStroud |
Dec 2 2012, 05:57 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Where in Norcal are you? Maybe there's someone near by that could look at it if you're not sure.
Jeff |
vitaminC |
Dec 2 2012, 06:50 PM
vitaminC |
Dec 2 2012, 08:18 PM
In case anyone wants to see the original ad: http://sfbay.craigslist.org/sby/cto/3436034010.html
Lo-Fi Version | Time is now: 21st May 2024 - 09:46 AM |
