PMB site down? |
PMB site down? |
DEC |
Dec 1 2012, 07:21 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
Is the PMB site down or is there another address?
balljoint |
Dec 1 2012, 07:44 AM
balljoint |
Eric_Shea |
Dec 1 2012, 04:08 PM
No notices or outages on my end. (IMG:style_emoticons/default/confused24.gif)
Jeff Hail |
Dec 1 2012, 08:56 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Momentary outage due to hooves and horns. A wee bit to much Alicorn in the water.
DEC |
Dec 2 2012, 02:49 AM
euro911 |
Dec 2 2012, 04:20 AM
It's working here.
MDG |
Dec 2 2012, 06:11 AM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Momentary outage due to hooves and horns. A wee bit to much Alicorn in the water. (IMG:style_emoticons/default/laugh.gif) |
DEC |
Dec 6 2012, 02:28 AM
via my company VPN in Andover, MA works the site.
It looks like that's Eric's site is blocked for Germany. I will ask Gustl if he has the same issues |
Eric_Shea |
Dec 6 2012, 09:28 AM
Checking with my hosting service.
Thanks for the notification. |
DEC |
Dec 7 2012, 02:13 AM
In Austria it works
Eric_Shea |
Dec 7 2012, 01:17 PM
Is it the same IP address you're using here? If not, PM me your IP address.
Thanks |
Eric_Shea |
Dec 7 2012, 05:06 PM
FYI:
QUOTE Thank you for contacting the Support Team. Our system did end up blocking the IP address you had provided as there was some suspicious behavior from a range of similar IP's. We have since unblocked the IP and your client should be able to access your website without any issues. If you have other concerns, please don't hesitate to contact us again. If you have a follow-up question or inquiry to this case, you can click on the 'Not Quite Yet' button below to respond. |
Lo-Fi Version | Time is now: 21st May 2024 - 03:39 PM |
