vacuum advance on distributor |
rmital |
Dec 10 2012, 08:18 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
using a mityvac on the vacuum port on the dizzy, at what value(hg?) would the vacuum advance move on the distributor?
'74 2.0L 039 905 205A 0 231 174 011 thanks, Ray |
SLITS |
Dec 10 2012, 08:39 AM
This might help you Ray ...............
Distributor Information I am sure you can figure out to look under distributor information ..................... |
rmital |
Dec 10 2012, 09:04 AM
This might help you Ray ............... Distributor Information I am sure you can figure out to look under distributor information ..................... ...dam Ron...lots of good info there. Thanks! I'll dig in later and hopefully figure it out. |
charliew |
Dec 10 2012, 09:50 AM
Look in the 914 manual and see what the total amount of vaccum the motor pulls, just guessing 25 inches. The book should say what the total amount of vaccum advance the dist gives. The mity vac should pull the plate around until it hits a stop in the dist. Put a vaccum gauge on the motor and see what the total vaccum it pulls is.
Lo-Fi Version | Time is now: 21st May 2024 - 02:55 PM |
