calculating ideal corner balance weights |
brant |
Dec 13 2012, 09:42 AM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
do folks around here calculate Ideal corner weights
we always do and usually can get within 1lb on each corner.. but I see everyone posting cross weights and no mention of calculated ideal weights... for those that don't you should really look into doing it. brant |
McMark |
Dec 13 2012, 10:56 AM
Any leads on the process? (IMG:style_emoticons/default/confused24.gif)
john rogers |
Dec 13 2012, 11:26 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Hummm, not sure what "ideal" would mean? When we balanced the 914-6 every winter we went with equal weights side to side both front and also rear. This was done with me fully suited in the driver's seat, cool shirt cooler loaded, full fuel cell and engine warmed up so oil would be distributed as per race trim. We never worried about front to rear or cross weights since all the tracks we ran on were pretty much even in loading and if they ran clock wise or counter clock wise.
What I was surprised with was the fact that the car's weight would change from year to year and we could never figure out why? My weight stayed the same and no changes were made to the car after we did the big weight reduction with all the fiberglass bits. |
brant |
Dec 13 2012, 11:33 AM
sure thing I use a paper version of the same formula's and a calculator (don't want to leave the garage and log into a computer) if you do the (simple) math... you will find most starting points about 30lbs off in each corner after carefully setting ride height. (Sometimes a corner will be 70lbs off depending on how carefully you set ride height.) by then making adjustments using the formula each time, you can bring the numbers closer and closer to ideal we usually stop in the 1lb range jacking ride height UP adds weight to that corner lowering ride height takes weight off you want to start with the corner that is furthest off in pounds from ideal I recommend making any changes, one corner at a time it takes longer but making multiple changes is more likely to set you in the wrong direction. (similar to jetting carbs... one thing at a time) we roll off of the scales for each change and don't forget to resettle the suspension (bounce it a lot) and zero-calibrate the scales before rolling back on for the next measurements. its a long process a few hours minium, and a half day if you have had the suspension off. |
brant |
Dec 13 2012, 11:36 AM
Hummm, not sure what "ideal" would mean? When we balanced the 914-6 every winter we went with equal weights side to side both front and also rear. This was done with me fully suited in the driver's seat, cool shirt cooler loaded, full fuel cell and engine warmed up so oil would be distributed as per race trim. We never worried about front to rear or cross weights since all the tracks we ran on were pretty much even in loading and if they ran clock wise or counter clock wise. What I was surprised with was the fact that the car's weight would change from year to year and we could never figure out why? My weight stayed the same and no changes were made to the car after we did the big weight reduction with all the fiberglass bits. ideal is pretty well explained in the link the lack of fine tuning to ideal is why your weights were changing year to year you can replicate total weight pretty darn close (5lbs or less) from year to year when you do this extra step to ideal this is the detail step(s) that most people skip. brant |
Dec 13 2012, 04:43 PM
Resident German Group: Admin Posts: 41,622 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
do folks around here calculate Ideal corner weights we always do and usually can get within 1lb on each corner.. but I see everyone posting cross weights and no mention of calculated ideal weights... I never try to get all corners equal, i try to get the cross weights equal ... (IMG:style_emoticons/default/shades.gif) |
brant |
Dec 13 2012, 05:04 PM
do folks around here calculate Ideal corner weights we always do and usually can get within 1lb on each corner.. but I see everyone posting cross weights and no mention of calculated ideal weights... I never try to get all corners equal, i try to get the cross weights equal ... (IMG:style_emoticons/default/shades.gif) when using the formula for ideal, none of the 4 corners are the same as each other.... Each corner shoots for a different ideal weight. its just a fine tuning of the cross weights |
Dec 13 2012, 06:59 PM
when using the formula for ideal, none of the 4 corners are the same as each other.... Each corner shoots for a different ideal weight. its just a fine tuning of the cross weights Ok, then that's what i do. Seems like the terminology is the confusing part .... (IMG:style_emoticons/default/biggrin.gif) |
0396 |
Dec 13 2012, 08:46 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
sure thing I use a paper version of the same formula's and a calculator (don't want to leave the garage and log into a computer) if you do the (simple) math... you will find most starting points about 30lbs off in each corner after carefully setting ride height. (Sometimes a corner will be 70lbs off depending on how carefully you set ride height.) by then making adjustments using the formula each time, you can bring the numbers closer and closer to ideal we usually stop in the 1lb range jacking ride height UP adds weight to that corner lowering ride height takes weight off you want to start with the corner that is furthest off in pounds from ideal I recommend making any changes, one corner at a time it takes longer but making multiple changes is more likely to set you in the wrong direction. (similar to jetting carbs... one thing at a time) we roll off of the scales for each change and don't forget to resettle the suspension (bounce it a lot) and zero-calibrate the scales before rolling back on for the next measurements. its a long process a few hours minium, and a half day if you have had the suspension off. I use a very same process as Brent....not down too the 1 lbs thought...he's the man too |
Woody |
Dec 14 2012, 07:20 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I can get my car exactly at 50% cross weights. I am running delrin bushings that I turned on a lathe for a perfect fit with no drag. I think its like splitting hairs at that point.
brant |
Dec 14 2012, 10:48 AM
I can get my car exactly at 50% cross weights. I am running delrin bushings that I turned on a lathe for a perfect fit with no drag. I think its like splitting hairs at that point. next time you corner balance, I would love to see you run your numbers and get back to everyone about how close/far off your rough numbers are... for me this is an economical way to improve the car for example: I figure I go to the effort of buying a better tire versus just a toyo because I want everything I can get out of the cars performance... So this is just one more way to improve the performance (although only slightly) brant |
Woody |
Dec 14 2012, 11:07 AM
john rogers |
Dec 14 2012, 04:15 PM
Humm, do you make the adjustments with you or whoever is driving in the car or do you bribe you wife to site there for all that time? I used to have to buy my wife dinner after she say through a balance session. You did not mention how level the area is that the scales are setup on? The set Black Forest in San Diego let me use had built in levels which was nice.
brant |
Dec 14 2012, 04:50 PM
I sit in the car...
fully race trimmed: 19qts of oil and 4 gallons of gas. when I go to alignment, I put balast weights into the drivers seat to replicate but I sit in the car when I corner balance. I do my best of balancing my garage floor. I use exactly the same position and location for the dozen or so years I've been doing this my buddy who is semi-pro on the dirt tracks has a beautiful metal table (like a celete bench) to scale his car on, but I've just been using a level floor. I have played with water tubing and strings in some attempts to check level in the past. |
Woody |
Dec 14 2012, 06:46 PM
I use our brand new hunter alignment rack. I think its kinda splitting hairs though getting down to the exact pound. I may be wrong. That kind of accuracy will change depending on how much you ate, how well hydrated you are, and if you relieved yerself before a run. I am certainly not a talented enough driver to tell a difference at that level.
john rogers |
Dec 18 2012, 07:30 PM
Something to consider is the track where the racing will take place and what direction the turns are and are there any long ones such as NASCAR turns 1 and 2 at CA Speedway or NASCAR turns 3 and 4 at PIR or turns 8 and 9 at Willow Springs. If you are loosing time when the car does not feel solid and you let off and loose time then a slight jacking of the weight and outside wheels might help. We used to do this at CA Speedway and actually setup the car loaded towards the left and I could keep the pedal floored and actually take a drink, check all the gauges and talk to the wife on the radio through #1 and #2.
Lo-Fi Version | Time is now: 5th May 2024 - 10:44 AM |
