| strawman |
Dec 13 2012, 07:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 891 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California
My 1973 914 came to me as a non-running basketcase, so I don't know if the tachometer even works. I suspect a DAPO repair on the tach gauge, as the needle is bent/tweaked, and the rubber bezel gasket is awry...
If someone nearby has a spare tach to sell cheap or even just borrow so I can hook it up to see if the signal from my Subaru ECU (modified with a 904SVO-designed tach converter) works, that would be worth some free beer from me. Alternately, I can reach under your dash and plug the tach signal wire and ground into my tach to see if it moves. I'm willing to drive an hour or so, or you can stop by and help me drink some good Holiday Ale homebrew outta my kegerator! I guess another option is for someone to explain how to test the factory 914 tach. Did a search, but found nothing. Anyone? |
| biosurfer1 |
Dec 13 2012, 07:50 PM
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
Geoff, PM me your address, it will be in the mail tomorrow
| JRust |
Dec 13 2012, 08:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Geoff, PM me your address, it will be in the mail tomorrow Ditto if Brett's doesn't work out I have one I can send (IMG:style_emoticons/default/smile.gif) |
| Elliot Cannon |
Dec 13 2012, 10:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
PM sent.
| strawman |
Dec 14 2012, 04:19 PM
Brett offered to mail a spare to me, but Elliott I'd welcome a chance to either come up to see your car-mods-in-progress or to host you for a beer or two while we stand around my car and listen to go vroom-vroom. Cheers to both of you, and for Jamie's back-up offer!
Lo-Fi Version | Time is now: 13th March 2026 - 01:54 PM |
