Another 5 Lug Conversion Question, Which front end? |
mharrison |
Nov 7 2004, 08:23 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
What year 911 front ends will bolt up to a teener? What are the various pros and cons, and which pieces will I need? I've looked through the archives, but the information is real spotty.
Thanks, Matt |
Brad Roberts |
Nov 7 2004, 09:14 PM
Stick with the 73 and up stuff. I personally wouldnt put anything less than a 78 setup on it so you get the 3.5 inch bolt spacing in case you want bigger calipers later. The early "S" stuff with the flexy aluminum calipers is 3.5 inch also.
Key is: all the caliper adapters available are designed for 3.5 inch spacing. All the early struts are 3 inch. B |
Lo-Fi Version | Time is now: 20th May 2024 - 12:10 PM |
