Dasnowman |
You miss 100% of shots you don't take! ![]() ![]() Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada ![]() |
I was going to sugget the hollow metal door also - Good suggestion Gint ;-);-) They work good for welding (magnets stick to them), and they are predrilled for hinges. Screw the hinges to the wall, and your work bench can fold flat against the wall. just add folding legs. Stu (IMG:style_emoticons/default/beerchug.gif) That is golden I have a two car garage but the wife will want it back sooner then later so this is a perfect solution for me. Happy wife happy wife, but she's cool she buys me tools to work on the teener! |
cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
I covered mine with cheap laminate flooring from home depot over top of 2x6's. Good and sturdy, easy to fix.
dian |
Member ![]() ![]() Group: Members Posts: 57 Joined: 21-September 11 From: switzerland Member No.: 13,583 Region Association: None ![]() |
i did exactly the same.
besides i poured this one (in the background): (IMG:http://www.914world.com/bbs2/uploads_offsite/i973.photobucket.com-13583-1356106650.1.jpg) another one: (IMG:http://www.914world.com/bbs2/uploads_offsite/i973.photobucket.com-13583-1356108177.1.jpg) (hope you dont mind my dirdy pyjama.) |
rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,673 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
I love this thread
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
I am with scotty on the freebies. I found some great parts just left behind in an old churchyard. I built a great work bench last summer with it. It's going to be great because you can just flip the top up and store all kinds of stuff in it, once I figure out how to get it unsealed that is. I also need to add a lower frame to bring the height up.
struckn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region ![]() |
Here's a PORTABLE HEAVY TABLE WORK BENCH 4' X 4' that I made out of 2x4's, 2x6's and white pre cut Laminate Partical boards 2ft x 4ft. The legs on one side only are cut shorter then the legs on the other side so that caster wheels can level and support the table. By lifting the opposite side it can be rolled around to any where you are working at. Also made several 2ft x8ft wall mounted benches using the white Laminated particle boards. They pretty tuff and reflect light plus easy to clean and not that expensive.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1356108963.1.jpg) |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
I am with scotty on the freebies. I found some great parts just left behind in an old churchyard. I built a great work bench last summer with it. It's going to be great because you can just flip the top up and store all kinds of stuff in it, once I figure out how to get it unsealed that is. I also need to add a lower frame to bring the height up. Ha ha ha ha, good one. Let's see, where are you from again? Good, now I know never to go anywhere near there. (IMG:style_emoticons/default/bye1.gif) . |
mhuber45 |
Newbie ![]() Group: Members Posts: 36 Joined: 14-September 11 From: St Louis Member No.: 13,557 Region Association: None ![]() |
i went to our local factory 2nd's building supply/junk store and got a kitchen countertop for $20-patern was jacked up, but works great/ i have 12' of counter top and another 4' of 3/8" steel plate
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
If you want to do a little elbow work, go to a local cabinet maker, get his scraps. Usually they are glad to get rid of them. Using a taable saw or planer, smooth down both edges ( most of the time they are goos to go ) and glue up. Finsh cut and top coat. That's all this butcher block I'm giving my parents for Christmas is (IMG:style_emoticons/default/smile.gif) Freebies and elbow grease (IMG:style_emoticons/default/biggrin.gif) Offset each strip by 50% and you can make as large a top as you want (IMG:style_emoticons/default/beerchug.gif) Nice job! That looks great. (IMG:style_emoticons/default/thumb3d.gif) kissass (IMG:style_emoticons/default/dry.gif) Ooops . . my bad - I meant to respond to Elliot's post. |
MDG |
Let's see, where are you from again? Good, now I know never to go anywhere near there. (IMG:style_emoticons/default/bye1.gif) . (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) Yes! See, Dave - I told you that would work. |
Brian_Boss |
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 ![]() |
All I can add to all the good ideas above is to say that it's nice to have both metal and wood tops, depending on the project. If you only have room for one bench, you might consider covering half with metal.
Now, the real reason for my post is to say how much I admire the discipline of the guys posting pics of the clean benches. I have two 3' x 6' benches and I frequently find myself hunched over working on the shop floor because both benches are covered in junk. I'm too embarrassed to post a picture. |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Eh... mine has crap on it all the time. Might as well post a pic.
You guys wanna see the 10' ... desk I have in my garage also? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I am with scotty on the freebies. I found some great parts just left behind in an old churchyard. I built a great work bench last summer with it. It's going to be great because you can just flip the top up and store all kinds of stuff in it, once I figure out how to get it unsealed that is. I also need to add a lower frame to bring the height up. ![]() Dual purpose....and biodegradable. (IMG:style_emoticons/default/14.gif) |
rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
Here's a PORTABLE HEAVY TABLE WORK BENCH 4' X 4' that I made out of 2x4's, 2x6's and white pre cut Laminate Partical boards 2ft x 4ft. The legs on one side only are cut shorter then the legs on the other side so that caster wheels can level and support the table. By lifting the opposite side it can be rolled around to any where you are working at. Also made several 2ft x8ft wall mounted benches using the white Laminated particle boards. They pretty tuff and reflect light plus easy to clean and not that expensive. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1356108963.1.jpg) Is that an f4u?? Super cool! Extra points if you built it and it wasn't an arf! |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
Attached thumbnail(s) ![]() |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
QUOTE Eh... mine has crap on it all the time. Might as well post a pic. You mean like this: (its sort of a where's waldo for 914 parts ;-) (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1356213715.1.jpg) Free butcher block work benches from work! (IMG:style_emoticons/default/piratenanner.gif) Stu |
struckn |
Here's a PORTABLE HEAVY TABLE WORK BENCH 4' X 4' that I made out of 2x4's, 2x6's and white pre cut Laminate Partical boards 2ft x 4ft. The legs on one side only are cut shorter then the legs on the other side so that caster wheels can level and support the table. By lifting the opposite side it can be rolled around to any where you are working at. Also made several 2ft x8ft wall mounted benches using the white Laminated particle boards. They pretty tuff and reflect light plus easy to clean and not that expensive. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-13764-1356108963.1.jpg) Is that an f4u?? Super cool! Extra points if you built it and it wasn't an arf! Thanks...Not a Corsair, it's a AT-6 Texan Mid West Kit, 80" wing and yes I'm a builder flyer for 20+ years. |
Gint |
(IMG:style_emoticons/default/icon_bump.gif) This thread is much too young to die...
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
You can find great ideas here. http://www.garagejournal.com/
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,912 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Yeah. Here you go ... roll away and bench in one movable unit (IMG:style_emoticons/default/idea.gif)
Lo-Fi Version | Time is now: 19th July 2025 - 05:07 AM |
