big engine build, D-tronic quest for the engine guys |
02loftsmoor |
Dec 23 2012, 04:27 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
Every one said to keep you orginal engine stock,,So I bought a shortblock, I have a 2.0 crank lined up with rods, an 11lb flywheel and 2.0 heads. I was looking at useing 103mm cylinders. Is the D-tronic able to handle the larger bore???
my D-tronic if from my 1.7 Wes |
Mike Bellis |
Dec 23 2012, 05:44 PM
Do you want it to run? or run well? I don't think the factory system can compensate for an extra 300cc's. Too many variables (more than extra CC's) for a "dumb" FI system to handle.
In my opinion, you would be better off going to programmable fuel injection. |
76-914 |
Dec 23 2012, 06:02 PM
if you have yellow injectors you'll need to change to green. you will need an A/F gauge installed to adjust (fatten) your MPS.
Dec 23 2012, 06:06 PM
Yes, it works with adjustment to the mps.
Rich |
JeffBowlsby |
Dec 23 2012, 07:20 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I dont know how big that is but I thought there was general consensus that 2056 was the biggest reasonable size for stock Djet?
02loftsmoor |
Dec 23 2012, 08:14 PM
02loftsmoor |
Dec 23 2012, 08:16 PM
help me here,, MPS??
messix |
Dec 23 2012, 08:50 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
manifold pressure sensor
Mike Bellis |
Dec 23 2012, 09:12 PM
2366cc I dont know how big that is but I thought there was general consensus that 2056 was the biggest reasonable size for stock Djet? I do not think you can run a 2.36L on the stock injection system. It is just too antiquated for such large displacement. You might be able to modify a mechanical system from a Rabbit to work but that won't be easy either. I think carbs or Megasquirt is in your future. |
messix |
Dec 23 2012, 09:25 PM
go l-jet
many many aplications out there to build a system that will work |
02loftsmoor |
Dec 23 2012, 09:44 PM
messix |
Dec 23 2012, 09:46 PM
Never heard of I-Jet Mega squirt yes go l-jet many many aplications out there to build a system that will work l= small L not i or I (IMG:style_emoticons/default/slap.gif) |
ConeDodger |
Dec 23 2012, 09:47 PM
Apex killer! Group: Members Posts: 23,589 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
In my opinion it can be done but the compromises in driveability aren't worth the trouble.
Mike Bellis |
Dec 23 2012, 09:52 PM
In my opinion it can be done but the compromises in driveability aren't worth the trouble. (IMG:style_emoticons/default/agree.gif) Exactly! Which is why I first asked... "Do you want it to run? or run well?" Two different ways to drive. There is nothing factory that you can just "bolt on" and go. Even if you can source enough L-Jet parts from various make and models, the money, frustration and time spent won't be worth it. CB Performance has a programmable system for around $1700. Or McMark can build you a bolt on kit. |
02loftsmoor |
Dec 23 2012, 10:24 PM
I may have to rethink this,, I have been reading up on the Mega squirt, is seems full of bugs, but what what I've been reading they may not fully understand the system,.
Mike Bellis |
Dec 23 2012, 11:30 PM
I may have to rethink this,, I have been reading up on the Mega squirt, is seems full of bugs, but what what I've been reading they may not fully understand the system,. It's not full of bugs but you do need to understand tuning principals. Each engine, even if setup identically will need a slightly different tune. Most newer EFI systems have some sort of self tuning ability. But you need the basic tune to be close for it to work. Find a tuner in your area and see what EFI system they specialize in. A Dyno and some tuning time is all you need for good running and HP. |
Dec 24 2012, 08:27 PM
i will say it again.
it works with djet. the injectors for the 2.0 liter support the 2.4 motor (71*103) The mps needs to be tuned while driving, at idle, and under load. But, the 'consensus' that is does not work is a disproven rumor. rich |
VaccaRabite |
Dec 24 2012, 08:48 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Rich, I don't doubt that it works.
I just doubt that it works well. There is going to be a lot of heat soak with 103s. Keeping the heads cool is going to be a challenge. It might make a great AX engine, where heat is not as much of a concern as the run is only 1 minute or so and you only run 5 or 6 times a day. I was thinking about doing exactly that with the race car Scott and Mike and I were going to build - but that car would not have been street legal. Making the engine drive to the event and back w/o overheating would get expensive I bet. Zach |
ConeDodger |
Dec 25 2012, 12:35 AM
Rich, I don't doubt that it works. I just doubt that it works well. There is going to be a lot of heat soak with 103s. Keeping the heads cool is going to be a challenge. It might make a great AX engine, where heat is not as much of a concern as the run is only 1 minute or so and you only run 5 or 6 times a day. I was thinking about doing exactly that with the race car Scott and Mike and I were going to build - but that car would not have been street legal. Making the engine drive to the event and back w/o overheating would get expensive I bet. Zach (IMG:style_emoticons/default/agree.gif) My point is that the LJet is much more flexible and in my opinion less fragile than DJet. Before Chris Foley you couldn't pray for a decent MPS. You can easily get a AFM rebuilt... |
Dec 25 2012, 04:46 PM
It works fine.
No heat issues, nothing dramatic nor complicated making it work just fine. Is there more hp to seek out with carbs and a camshaft, sure there is. Then you have heat issues. For a very fun, and cheap fast motor, 71 * 103 will put a big smile on your face and with the same stroke, the injection functions just fine. Have any of you guys with custom motors driven 10k miles yet? It's really a simple build that has been done for over 30 years. No complexity nor added stress from a longer stroke...which does add new stress. Don't believe me, call and ask FAT performance. Rich |
Lo-Fi Version | Time is now: 18th May 2024 - 05:07 PM |
