big engine build, D-tronic quest for the engine guys |
Dec 25 2012, 04:57 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Btw, from experience.
48/38 is a high revving track motor, not so great around town. 46/38 is a sweet setup that you can wind up till the valves float 44/38 is a nice tame version that runs nice. Spend the money on a nice valve job, and port the 44/38 setup and you will love the motor. This is probably the best setup for all around use, decent port velocity and its cheap fun...no special case work aside from milling out for the jugs. No need for external oil cooler unless you are on the track only...for street and autos, it's fine with the stock setup. Again, being a CSOB, I don't think trying to get more than 180 hp out of a type 4 motor makes to much sense to me....it starts to cost a lot more money right about 180 or more. That is really plenty of reasonably priced fun with a 914 |
CG-914 |
Dec 28 2012, 07:30 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
To the over heating topic:
I do agree with rich (IMG:style_emoticons/default/agree.gif) Heat is caused by compression not bore! What I'd like to know is, what cam are you planing to run? Would the 9550 still work? |
Lo-Fi Version | Time is now: 9th June 2024 - 07:04 PM |
