Heater lever kills electrical |
mtndawg |
Dec 23 2012, 11:59 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I picked up a 914 a couple of weeks ago and am now sorting through it to get it on the road. Today I cleaned up the throttle body and put it back into the car, while I was idling, I pulled the heater lever and it killed the electrical, I put lever down and started the car once more, again pulled the heater lever. The second time, the electrical went out, now I'm not getting any power. What could cause this?
mittelmotor |
Dec 24 2012, 12:04 AM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
That lever contains a switch that powers the heater squirrel-cage fan in the engine compartment. Apparently there's a short in the circuit.
Dec 24 2012, 12:08 AM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
That lever contains a switch that powers the heater squirrel-cage fan in the engine compartment. Apparently there's a short in the circuit. (IMG:style_emoticons/default/agree.gif) The heater blower circuit is running through the same fuse (on the relay board) as the fuel pump. Check the fuses on your relay board. One should be blown. Then find the short in the heater blower/lever circuit. (IMG:style_emoticons/default/popcorn[1].gif) |
steuspeed |
Dec 24 2012, 12:10 AM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Check the relay on the engine compartment relay board. IIRC it's the one at the bottom of the board or the one furthest toward the back of the car. Mine just went out, and I replaced it with my fog light relay from under the dash to get by. There is also 2 fuses on the board. The small one is for rear window defrost (most cars don't have this) and the othe one is for everything else on the board. You might have popped that. You can also unplug the fan in the engine compartment and hook it up to the battery with some wires to see if it runs okay.
Mike Bellis |
Dec 24 2012, 12:16 AM
The lever sends a ground to the blower fan. If your fan is bad, you may have sent a direct short to the electrical system.
Most likely a blown fuse(s) somewhere. Make sure the correct size fuse is installed OR the wiring will turn into the fuse... (IMG:style_emoticons/default/sad.gif) |
76-914 |
Dec 24 2012, 01:57 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Did you run 12v + to the "Heat On" indicator light?
drdave427 |
Dec 24 2012, 06:18 PM
Newbie Group: Members Posts: 31 Joined: 26-March 12 From: East TN Member No.: 14,306 Region Association: South East States |
76-914 |
Dec 25 2012, 10:29 AM
yea, that one. but judging from your response you obviously didn't.
Tom |
Dec 25 2012, 12:18 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Clarification for the relay board fuses.
The front fuse is for use on Sportamatic cars. Rear fuse powers fuel pump, AAR, rear window defroster, and heater fan. most folks use the front fuse holder to keep a spare fuse in. Although the Haynes manual calls for a 25 amp fuse, if you are not running a rear window defrost, use a 16 amp. I don't have my heater fan in and only run an 8 amp. Always use the lowest amp fuse that the circuit will allow. Fuel pump is about 5 amp, heater fan about 5 amp, AAR is about 1.5 amp. So a 16 should be fine. Tom |
Lo-Fi Version | Time is now: 26th May 2024 - 11:56 PM |
