starter question, need more power |
freezing14 |
Nov 8 2004, 09:15 AM
freezing14 Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 |
Ok i get ready to start by newly rebuilt 1.7 bored to 1.8 with ss valve and upgraded spring with swivell foot adjuster,, the engine crank ok without the spark plug, but the starter is not strong enough to crank with the plugs on , I check the the crack was free reving by removing all the rocker just to make sure and it cranks just fine with the plugs, but if I add the rocker which also turn freely on the shaft, it cannot crank, those dawn bugger spring are stiff,, now i know i need a new starter, but like most of you I am cheap , so what are my options,, bus starter,911 starter,, can you upgrade the 914 core to give it more torque, keep the core, cheaper,, or is it just because it is a 30 year old starter,, By the way i tried 2 starter, a new battery, the one from My S4 and the car is a 72 1.7 d-jet
machina |
Nov 8 2004, 09:33 AM
Maybe you have a bad ground or need a new battery.
I have close to 11:1 CR and dual springs and an antique starter, works just fine. |
crash914 |
Nov 8 2004, 09:37 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Well, I found out why my motor was hard to crank...one rocker arm siezed on the shaft...was holding open the intake valve...the motor did run though..the stock starter is strong.
I (before I found the problem) ordered an IMI high torque starter...its the bomb...spins the motor over with no problem and half the weight.....freed up the rocker arm (made a nice groove in the shaft). You can find one for about $200 to $225. Check with HPH, or search here or ebay... just remember, the stock starter will turn over a high compression motor.. If it won't, there must be something wrong.... good luck! |
freezing14 |
Nov 8 2004, 10:50 AM
I have checked all the moving part for stikyness, the crank , the rocker, the valve, and everything is free moving, , would a high lift cam and super valve spring do this,, anyone has the stock lift and time of the stock cam to compare with the one I got
Lo-Fi Version | Time is now: 28th April 2024 - 02:06 AM |
