BMXerror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 ![]() |
Calling all racers. I haven't had much time to mess with the 914 since finishing the SDS install nearly a year and a half ago. It's got a pretty decent baseline map in it (street tune, no dyno), but it's always been a hard cold starter. It will crank and crank and nothing, but as soon as you let go of the starter it stumbles and tries to fire. Keep doing this and it will eventually start. Just this past few weeks I've gotten back into it and am trying to resolve this issue. And after successfully testing one of my father's theories, I've found the problem. The starter is robbing too much power from the coils, and they're not firing while the starter is engaged. I confirmed this with an inductive timing light. So the question is what to do about it.
Some background info: *The starter is an ebay high torque starter and has been installed for some time. It started just fine with the D-Jet system. *The injection is an SDS EM-4F, meaning it's crank fired with two coil packs(batch fire). Supposedly it's a pretty hot spark. *Part of my SDS install was relocating the Battery to the front. Currently I have the secondary lead on the starter running through the tunnel, and the hot lead that runs the injectors and coils pulled off of the starter pole. However, in my testing I ran a test lead direct from the battery to the coils, and it didn't seem to help the situation. *I'm seeing a voltage drop at the battery to 8.5V when I hit the starter. *The battery is fairly new and seems strong, reading 13V at rest. Any recommendations on how to resolve this problem. It just seems to me like those coils and that starter are too much for that system. Input appreciated. Mark D. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
There is your problem. Since you are using an electronic ignition, it must have a minimum operating voltage that is above 8.5V. Sounds like you need a new battery to support the high-torque starter, or you need a new starter that doesnt pull the voltage down so far. You have me interested since I also have the ebay high-torque starter, but have not used it yet. You might have poor connections in the system which increases the voltage drop. Try cleaning every electrical contact between the battery & the starter and ignition module and sealing with electrical contact sealer. Stu |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
It sounds to me like the "Hot While Cranking" wire is either not working or you have the wrong wire connected to the coil.
I think your either connected wrong or the ignition switch is bad or you need a larger battery cable. While in theory it is possible to have such a voltage drop normally, this would mean you wiring system is too corroded to function properly. You could test by adding a diode between the starter wire and the ignition wire. Make sure you connect the polarity correct. On way will allow starter (cranking) power to energize the ignition wire, the other way will cause the run position to crank the starter (you do not want this). If this works, the ignition switch is bad. If it does nothing, the electrical system needs a look see. What size battery primary cable are you running? Where is the battery grounded? I run a 4/0 power and ground from the front trunk. Ground lead bolted to the engine block. I have no issues cranking or starting. |
BMXerror |
Running 4ga wire through the tunnel to the starter. The ground is on a battery switch at the front, also with 4ga wire running to it. The switch sticks out of the front fender where the radio antenna normally is. The wiring is all new due to the recent SDS install, though I suppose it's possible that my ground is less than optimal.
The stock ignition switch is no longer operational. It's now three separate toggle switches, with the first one switching power to the injectors and coils, the second one switching on the ECU, and the last one being a momentary for the starter. I'm gonna try a different ground and see if that helps the situation. Mark D. |
BMXerror |
Well, that was easy... Tighten the f-in ground, dumbass! (IMG:style_emoticons/default/slap.gif) The connectors on the ground switch were loose. Not sure when or how that happened, but they were. I tightened them up and it starts much easier, though I haven't tried to cold start it yet. I also checked the voltage at the battery and it drops to 10.5 when cranking now. I'm not sure if this is still unacceptable or not, but it's an improvement.
That explains why the situation has seemed to deteriorate. I remember the first night I started it up on the new injection system, reaching in the window, hitting the starter switch, and it firing up without all that hassle. I must've been working on it shortly thereafter and pulled the ground off or something, because it's been doing this for months. Just haven't had time to investigate. Thanks KG6DXN. You had me looking in the right spot. What do you think of the new 10.5 cranking voltage? Mark D. |
Mike Bellis |
What do you think of the new 10.5 cranking voltage? Mark D. I would say that is a normal voltage drop. You could improve it with a bigger battery cable. #4 is a little less than optimal for the distance. See if you can find some 1/0 to 4/0 welding cable. It is fine strand flexible cable. I would also bond the ground up front to the chassis before it travels to the rear. After 40 years, our chassis ground is not what it used to be. #4 is good for 70 amps (AC current). DC current takes a larger wire. Starters can draw up to 200 amps DC peak... Peak current happens at maximum torque (start up) on an electric motor. This is why Edison needed a 3" diameter conductor to push 1/4 mile (DC current). Tesla pushed the same 1/4 mile with a #8 conductor (AC current)... The rest is electrical history... BTW most of Tesla's inventions are still in use today. Not the same for Edison... |
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
I was experiencing the issue where it would crank forever, wouldn't start, but when turning the ignition off, it would finally start. It got worse, then I could never start it. Cold. I spent hours troubleshooting it.
McMark solved it in his shop. (IMG:style_emoticons/default/beerchug.gif) It was a bad ignition switch. And, it was a "new" one. Lame! He explained it was actually cutting power to other components when fully turned, and would hit the sweet spot to start it. Oh yeah, I've been through the "bad ground" already - the OEM post above the battery was all rust! I now ground to the engine. I just wanted to add all that because I'm bored, and like you know, 914 World gets the most responses, fastest, of all auto-forums! (IMG:style_emoticons/default/aktion035.gif) |
BMXerror |
... and like you know, 914 World gets the most responses, fastest, of all auto-forums! (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/aktion035.gif) Thanks for helping to prove me right. (IMG:style_emoticons/default/beerchug.gif) Mark D. |
Lo-Fi Version | Time is now: 13th July 2025 - 10:21 AM |
