Early Console Clock, Have you ever seen one of these? |
914Sixer |
Dec 25 2012, 07:03 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Tom T mentioned his clock in the console was a non-quartz clock. I had never seen one in my 25+ years of playing with 914's. I finally have one to share with the World. It is based on the 911 clock of the time period with the plastic rear housing. It is the same clock part used in VW model clocks also. I added the late metal housing quartz clock as a reference
Woody |
Dec 25 2012, 07:17 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Most likely from a later year car.
bembry |
Dec 25 2012, 08:37 PM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
Yes--the Kienzle--it is an electro-mechanical clock. I have one in my 73 2.0.
Mike Bellis |
Dec 25 2012, 09:39 PM
Tom_T |
Dec 26 2012, 12:04 PM
(IMG:style_emoticons/default/agree.gif) .. yes, they changed in74 MY to the Quartz Zeit. The Kienzle's were considered very reliable, but the quartz more accurate & simpler mechanism, which was probably cheaper, as was the change from glass to plastic gauge lenses on the 3 pod instruments.
North Hollywood Speedo & Palo Alto Speedo can convert the innards of the earlier 911/912 & 914 to quartz & keep/restore the face as Kienzle - if you're having any VDO instruments repaired &/or restored by them. More good MY fitment info here: http://p914.com/p914_gauges_clock.htm BTW - the Kienzle will probably have a bit more current draw - being mechanical - than the Quartz Zeit, for those who drive their 73 914's & others with the early clock infrequently, & don't use a trickle charger/maintainer |
pilothyer |
Dec 28 2012, 04:59 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Good info on the clocks http://www.p914.com/p914_gauges_clock.htm
Lo-Fi Version | Time is now: 28th May 2024 - 08:17 AM |
