> 73 2.0L Idle problem
cwpeden
post Dec 26 2012, 01:34 AM
Great White North, huh?
I'm trying to help a friend solve an idle problem. Idle is low to the point of stalling and backfiring.
Here's what we have tryied so far:
Grounds are good
Timing is good
Dwell is a litlle high
Vacuum hoses are good
Cyl head temp sensor good
Ballast resistor good
Points good
Cap good
rotor good
Been through two trobleshooting guides with no results.
Need help figuring out a peculiar problem. When I take the vac lines off the dist I get the the usual high revs but they dont go away when the lines are plugged. Could this be a symptom of a bad vac can on the dist?
Any thoughts
914itis
post Dec 26 2012, 05:44 AM
Was timing set with the vac lines plugged? Try to cap the vac lines going to the dizzy and report back.
cwpeden
post Dec 27 2012, 03:24 AM
Timing set with vac lines off the dist and plugged.
Thing is, everything seems to work fine except for idle. Smells like too much gas.
Bleyseng
post Dec 27 2012, 10:48 AM
Aircooled Baby!
MPS is correct number (037) and tests good with a vac tester at 15hg for 5 min?
cwpeden
post Dec 27 2012, 03:55 PM
Does MPS affect idle mixture?
If it was bad I would expect a vacuum leak and high idle. Not 700 down to stall....right
euro911
post Dec 27 2012, 04:34 PM
There's not much vacuum being drawn above idle, so a leaky MPS shouldn't affect the mixture too much at higher throttle positions.
Have you checked out PBander's site on troubleshooting?
914_teener
post Dec 27 2012, 04:57 PM
QUOTE(euro911 @ Dec 27 2012, 02:34 PM) *
I think what Geoff is saying is that your post doesn't rule it out.
Mark....I think vacuum is highest at idle...with due respect... he mentioned at idle.
Could be both MPS and distributor.....ask me how I know. I would suggest you rule out the MPS first.
euro911
post Dec 27 2012, 05:36 PM
QUOTE(cwpeden @ Dec 27 2012, 01:55 PM) *
I guessed I missed the high idle part, Rob.
Not discounting a bad MPS, conducting a simple test with a Mighty-Vac will tell. However, a slow leaking MPS still works OK (not as good as a fully solvent one, of course).
The lower the idle, the higher the vacuum, so yes, a real bad MPS will affect the idle mixture.
Cap'n Krusty
post Dec 27 2012, 06:06 PM
Cap'n Krusty
QUOTE(cwpeden @ Dec 25 2012, 11:34 PM) *
Grounds are good
Timing is good
Points good
Cap good
rotor good
Any thoughts
Ummm, Yeah. What "ballast resistor"? 914s don't have a ballast resistor.
The Cap'n
euro911
post Dec 27 2012, 06:17 PM
Valves adjusted correctly?
Dwell should be somewhere between 44 & 49 degrees (optimally)
Idle speed adjustment on ECU (pot wiper or trace corroded)?
Idle adjustment on throttle body?
cwpeden
post Dec 28 2012, 02:10 AM
QUOTE(Cap'n Krusty @ Dec 27 2012, 04:06 PM) *
Grounds are good
Timing is good
Points good
Cap good
rotor good
Any thoughts
The Cap'n
I meant the inline resistor on the CHT sensor. not sure why I called it a ballast resistor. Must have been thinking of something else.
Will check the MPS though and probably need to pull the dist. for a thorough cleaning. and vac can test. I'll bet the ground wire in the dist is loose too.
Just to clarify. With everything hooked up the idle is low to the point of stalling and backfiring. When I pull the hoses to set the timing the idle goes up as expected, but dosent return to normal when the hoses are plugged. Should it?
thanks for the suggestions.
euro911
post Dec 28 2012, 10:17 AM
Are you sure the two vacuum hoses to the dizzy are going to the correct vacuum ports? (not reversed)?
914_teener
post Dec 28 2012, 01:03 PM
QUOTE(euro911 @ Dec 28 2012, 08:17 AM) *
Good point Mark.
I had the advance can go bad once and the mech advance plate inside the dizzy in dire need of lube when I first got the car. I would check those out as well. Sounds like the dizzy to me. Make sure everything is working and lubricated in there.....if it is the stock unit.
cwpeden
post Dec 29 2012, 06:41 PM
I'm feeling the same myself, about the condition of the dist. Think I'll just pull the good dist out of my car with the pertronix and see what happens.
cwpeden
post Jan 11 2013, 01:29 AM
Finally had the chance to go to my friends place tonight to work on his car. Brought my good MPS and Dist. with me.
Tested his MPS and it was good, vacuum wise. Swapped mine in anyways and no change.
Swapped in my dist. with pertronix and started right up smooth idle at 1100 rpm and settled down abit.
I have his dist on my bench and now I get to learn about distributor rebuilding. Cant be that hard.....right?
euro911
post Jan 11 2013, 01:44 AM
If you don't already have a 'MightyVac' get one. They're relatively inexpensive and an invaluable automotive diagnostic tool serving many applications.
Vacuum canisters, MPS', AARs, and hydraulic systems.
- Lo-Fi Version Time is now: 29th April 2026 - 05:16 PM
