How to Distinguish a SoCal 914 Owner, from the rest |
76-914 |
Jan 2 2013, 11:35 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
No, it's not the amount of rust. It's the ability to properly operate your heater controls. No (IMG:style_emoticons/default/stromberg.gif) It was a cold day yesterday A.M. during our run. I asked 3 other guy's in our group, "What is the proper positioning of these knobs for heat". Got 3 different answers. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/av-943.gif)
Tom_T |
Jan 2 2013, 12:08 PM
If I can make it to one of your dawn patrols (sans my 914 at this point), then I'll show you! (IMG:style_emoticons/default/biggrin.gif)
It's actually pretty cool, cuz you can put cold/cool air on your face & heat below, which comes in handy on long drives where you want to stay warm but not get drowsy from hot/warm air in your face/eyes! (IMG:style_emoticons/default/driving.gif) The 914 is the only car I've had or driven that was set up to do this (including many rentals on biz trips over the years). |
euro911 |
Jan 2 2013, 12:10 PM
I always thought it went like this:
Top lever controls the fan speed control (fresh air fan) Middle (Red) lever is the temperature control (L=Cold, R=Hot) Bottom lever controls direction (L=Under dash vents, R=Windshield defrost vents) The console lever adjacent to the shift lever opens heat valves in engine compartment, allows heat from engine to enter the fresh air venting system. There's also a switch on this lever to power up the fan motor in the engine compartment. |
Tom_T |
Jan 2 2013, 12:23 PM
I always thought it went like this: Top lever controls the fan speed control (fresh air fan) <--- in front trunk/cowl Middle (Red) lever is the temperature control (L=Cold, R=Hot) v-- Middle area is varying % of Both & far ends are heat to one direction up/down only Bottom lever controls direction (L=Under dash vents, R=Windshield defrost vents) Pull up for heat, further up for more heat from flappers, max @ top - fan in engine bay comes on as soon as it engages heat with the heater control box flappers ---v The console lever adjacent to the shift lever opens heat valves in engine compartment, allows heat from engine to enter the fresh air venting system. There's also a switch on this lever to power up the fan motor in the engine compartment. Dash & floor controls give you 2 points of heat control, which most folks forget to get both adjusted to comfort. In addition to the bolded notes with additional info above, you can retro fit any pre-75 914 with the y-branch at the engine bay fan with a hose to the passenger side heat supply tube in the longs. (this was std. in 75-76) for more cabin heat. |
Rockaria |
Jan 2 2013, 12:27 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
This morning was 24 degrees F when I drove to work. I have these levers down to an art. This information is for a stock 914 that has all working parts.
DASH: Top lever (Fresh air fan): Left - No freah air Center - Fresh air no fan Right - Three fresh air fan speeds DASH: Middle Lever (fresh air location): Left - Fresh air to feet Middle - Fresh air to vents Right - Fresh air to windshield DASH: Bottom Lever "mine is red" (Warm Air when red floor knob is pulled): Left - Warm air to feet Middle - Warm air to vents Right - Warm air to windshield FLOOR: Knob near shifter - Pull up on red knob below shifter for heat - The higher the knob the more heat. - Pull up more and at some point the fan in the engine bay will kick in |
914Eric |
Jan 2 2013, 12:58 PM
Member Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
This morning was 24 degrees F when I drove to work. I have these levers down to an art. This information is for a stock 914 that has all working parts. DASH: Top lever (Fresh air fan): Left - No freah air Center - Fresh air no fan Right - Three fresh air fan speeds DASH: Middle Lever (fresh air location): Left - Fresh air to feet Middle - Fresh air to vents Right - Fresh air to windshield DASH: Bottom Lever "mine is red" (Warm Air when red floor knob is pulled): Left - Warm air to feet Middle - Warm air to vents Right - Warm air to windshield FLOOR: Knob near shifter - Pull up on red knob below shifter for heat - The higher the knob the more heat. - Pull up more and at some point the fan in the engine bay will kick in Thank you...That is beautiful! |
'73-914kid |
Jan 2 2013, 01:49 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
People in socal even have heaters on their 914s....?
I prefer headers over heaters... (IMG:style_emoticons/default/biggrin.gif) |
damesandhotrods |
Jan 2 2013, 02:13 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
People in socal even have heaters on their 914s....? I prefer headers over heaters... (IMG:style_emoticons/default/biggrin.gif) Chicks dig cars with heaters. Especially if you’re going to drive around at night topless… |
euro911 |
Jan 2 2013, 03:12 PM
I was incorrect with the layout of the levers (IMG:style_emoticons/default/screwy.gif) ... red is bottom lever, duh
I'm color blind, which made it easy on my parents when I was a child ... they only had to buy me one color of crayons |
Jan 2 2013, 03:17 PM
middle, middle, middle, all the time (IMG:style_emoticons/default/smile.gif)
Never change them. Pull lever to turn on heat. rich |
Tom_T |
Jan 2 2013, 09:54 PM
Or we could look at the owners manual, & get past all of our half-zymers issues! (IMG:style_emoticons/default/laugh.gif)
(IMG:style_emoticons/default/popcorn[1].gif) |
Rockaria |
Jan 2 2013, 10:48 PM
Or we could look at the owners manual, & get past all of our half-zymers issues! (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/popcorn[1].gif) Show of hands for those that actually have the owners manual anymore! (IMG:style_emoticons/default/wavey.gif) Okay, it's online as well... But what the hey... |
mittelmotor |
Jan 2 2013, 10:55 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Wow, there's a map pocket on the underside of the center cushion? I'll have to check mine. Was it an option?
I was on the Dawn Patrol run with no heat...well, just enough radiant heat from the engine, coolant plumbing, etc. to take the edge off. Brrr! I just had to think warm thoughts...glowing charcoal, Apollo capsule on re-entry. Yes, I have the owner's manual! But no other real documentation, or service stamps in the back. |
Elliot Cannon |
Jan 2 2013, 11:03 PM
Heat. You all have heat? (IMG:style_emoticons/default/WTF.gif) Wear some clothes and roll up the windows. (IMG:style_emoticons/default/happy11.gif)
Eric_Shea |
Jan 2 2013, 11:11 PM
All along I thought it was the bumper sticker. (IMG:style_emoticons/default/confused24.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.azuregreen.net-1110-1357189912.1.jpg) |
914_teener |
Jan 2 2013, 11:29 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
All along I thought it was the bumper sticker. (IMG:style_emoticons/default/confused24.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.azuregreen.net-1110-1357189912.1.jpg) I knew it wouldn't be long before Eliyut would chime in! Congrats on your son's wedding. Hey it's been below 40 for the past week at night. That's more than anyone can bear down here. Who knows....rust may happen at those temperatures. I stand edjukaded now that I know how to work the kintrols. I'll have to install the aux. heater fan that's been sitting on the garage shelf now gathering dust. |
euro911 |
Jan 2 2013, 11:37 PM
Well, now I can print this and keep a copy in that secret map pocket in the center cushion, just in case I forget how the damn controls work in the future (IMG:style_emoticons/default/laugh.gif)
... and there's an escutcheon plate for the heater lever? (IMG:style_emoticons/default/confused24.gif) ... who has one of those??? |
vw505 |
Jan 3 2013, 07:49 AM
Member Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
I drove around half the summer with the pass side open blowing heat into the car.
sean_v8_914 |
Jan 3 2013, 09:10 AM
but then you might forget about the secret pocket
Steve |
Jan 3 2013, 11:08 AM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Pretty sad, but i keep the bottom lever to the left, otherwise i get oil film on the windshield when I turn on the heat. That's my favorite setting anyway. The top lever middle to right, depending on how much air i need. The middle lever to the right, to force fresh air out the top vents. The bottom lever to the left to force hot air out the bottom. Perfect settings for when the top is off and its cold out. I definelty used the heater a lot more in Northen Cal. versus So. Cal, but heat is still nice to have.
Lo-Fi Version | Time is now: 15th May 2024 - 01:20 PM |
