flapper box heater attachment - RESOLVED!, with help from this board - many thanks!!!! |
tadink |
Jan 5 2013, 04:03 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
hi guys -
I'm under the car trying to hook up my heater system - but the wire cable connector from the heater lever in the cabin to the flapper box under the car has me flumuxted! How do you connect the wire heater pull cable to the flapper box? anyone have a picture and maybe I can "McGiver" something together.... thx td |
Dave_Darling |
Nov 26 2015, 08:52 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The barrel nut should be able to crank down enough to even hold onto a bare wire. You might be able to crimp or solder on a thicker end if you feel it's necessary.
--DD |
barefoot |
Nov 26 2015, 09:10 PM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
The barrel nut should be able to crank down enough to even hold onto a bare wire. You might be able to crimp or solder on a thicker end if you feel it's necessary. --DD You can buy crimp sleeves used on fishing line, check your hobby shop as well. I purchased a beetle heater cable set cheap but have not pot things together yet to see if that will work. An official 914 heater cable is $$ Barefoot |
Lo-Fi Version | Time is now: 15th May 2024 - 02:00 AM |
