flapper box heater attachment - RESOLVED!, with help from this board - many thanks!!!! |
tadink |
Jan 5 2013, 04:03 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
hi guys -
I'm under the car trying to hook up my heater system - but the wire cable connector from the heater lever in the cabin to the flapper box under the car has me flumuxted! How do you connect the wire heater pull cable to the flapper box? anyone have a picture and maybe I can "McGiver" something together.... thx td |
Spoke |
Jan 6 2013, 07:46 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The cable ends on my car were cut when I bought it.
I got some wire of similar gauge and tiny U clamp from the hardware store to extend the cables. The cable extensions don't have the special end but those aren't necessary to terminate the cable at the flapper valve. Attached image(s) |
arsprod |
Nov 26 2015, 01:55 PM
Member Group: Members Posts: 199 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
The cable ends on my car were cut when I bought it. I got some wire of similar gauge and tiny U clamp from the hardware store to extend the cables. The cable extensions don't have the special end but those aren't necessary to terminate the cable at the flapper valve. Sorry to be a zombie but how did you connect the bare wire to the flapper box arm? I have wire but both ends broke off. |
rgalla9146 |
Nov 27 2015, 07:56 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The cable ends on my car were cut when I bought it. I got some wire of similar gauge and tiny U clamp from the hardware store to extend the cables. The cable extensions don't have the special end but those aren't necessary to terminate the cable at the flapper valve. Sorry to be a zombie but how did you connect the bare wire to the flapper box arm? I have wire but both ends broke off. Use a long cotter pin to replace missing wire ends. The cotter pin goes through the barrel nut. The broken wire end is looped through the hole in the cotter pin. Easy fix. Picture. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 14th May 2024 - 10:03 PM |
