'73 Resto & Suby 6 Conversion, or a primer on "How to convert your 914 to a Subaru 3.0" |
76-914 |
Jan 9 2013, 10:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What's it been? A year since I got Blackie running. I finally get it tuned to a daily driver status and should have been happy as a Lark then but what do I do? I sold the engine (w/90 hour's on the Hobbs) on the last Dawn Patrol GMR run. So I pulled the engine and began preparing Blackie for her transformation.
Before I go any further check out my Jack Stands. Min height 19.5", 12 ton and should hold up to a 6.7 quake or direct nuclear attack. And out she comes. One thing you have to love about these cars is that you can remove an interior in 15 minutes. 30 min's if you have a console. This was one shot before the interior is gutted. and an hour later I'm scraping tar floorboards. |
Chris H. |
Jan 14 2013, 11:29 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Sure no prob. I have learned that no matter how cheap you think it will be ...it will always fall into line with most other options.
The car was $600. It was mechanically great but cosmetically not so good. I was able to drive it home which was a plus. Most important thing is to listen and observe the engine...when you start it, it should idle about 1500 or so, then settle to a very even idle of 800ish. Watch the temp and look under it for leaks. You should be able to tell if it's strong or not. Expect to change the seals unless you get lucky like BIGKAT and find one that is practically new. These leak oil just like 911 engines after a while. At this point the stuff has totaled: Car - $600 WRX Trans and flywheel - $800 coldwaterconversions stuff (everything but the hard engine mounts) $1375 Custom exhaust and related goodies, plus another mount - $350 Engine seals, timing belt, spark plugs, etc ~$400ish 1990-1992 Honda Accord shifter - $40 shipped Still need radiator hoses, cable shift linkage, cables, some CV joints, a clutch disc, slave cylinder, etc. Probably another $800 or so. Keep in mind that you can part out the SVX and recoup some costs. All of the small stuff can be sold (switches, controls, mirrors, interior stuff, lenses). The differentials, axles/cv's and most importantly a good trans are worth $. Also the leather interiors are very desirable. SVXWorld.com is a good place to sell stuff. Just wait til I am done (IMG:style_emoticons/default/biggrin.gif) (Kidding, it doesn't matter there are several part-outs on there now). A metal scrapper paid $150 for the shell. I'll sell my current TIV engine, side shift trans, linkage, etc. (hey side shift conversion people!)and should be looking pretty good. I will also do a 5 lug conversion. Already bought the wheels. Got a great line on the rest as well... I figure the net will be $6k ish...so let's call it $12k. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) The cool thing about the SVX is it's very powerful in stock form so you can use most of the stock components as well as the niceties like air cond, real heater, etc. You can also use the fuel pump which makes it convenient. And they are pretty cheap. They are extremely similar to 914's. Manufactured roughly the same number of years, quirky but cool, a little too expensive when new, all years are identical shells with small cosmetic revisions each year. They are in the same place 914's were in the late '90's...lots of part-outs, not a lot of love, small following of fanatics... weird.... |
Lo-Fi Version | Time is now: 10th May 2024 - 08:43 PM |
