'73 Resto & Suby 6 Conversion, or a primer on "How to convert your 914 to a Subaru 3.0" |
76-914 |
Jan 9 2013, 10:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,453 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What's it been? A year since I got Blackie running. I finally get it tuned to a daily driver status and should have been happy as a Lark then but what do I do? I sold the engine (w/90 hour's on the Hobbs) on the last Dawn Patrol GMR run. So I pulled the engine and began preparing Blackie for her transformation.
Before I go any further check out my Jack Stands. Min height 19.5", 12 ton and should hold up to a 6.7 quake or direct nuclear attack. And out she comes. One thing you have to love about these cars is that you can remove an interior in 15 minutes. 30 min's if you have a console. This was one shot before the interior is gutted. and an hour later I'm scraping tar floorboards. |
76-914 |
Apr 8 2013, 09:23 PM
Time to get the suspension upgraded. I've covered most of this in other threads but I thought I'd at least hit the highlights here so I can relive it from the old age home one day. 1st some 914 porn courtesy of PMB.
I began with the L front. I had done ball joints/tie rods, brakes, etc. previously so shocks were all that were necessary. The old shock was a blown out KYB which accounted for a noise I heard occasionally. When I dropped the new Bilstein it went 90% in and stopped. The old shock was narrow but this new one is fat and binding. Pulled it out and looked inside and found this bit of rust. Ran a 2" wire fitting brush thru it several times. I even ran a rotary file over the areas that had rust, in case the metal had raised but it still would not fit. (IMG:style_emoticons/default/stromberg.gif) I discovered that area where it bound was the spot where the brake tab is welded on. It probably took a hit there and PO replaced with these skinny shits as a go around. Anyway, my buddy Ethan had these laying around so I cleaned up the L one and I was back in business. Bought this little tool to aid in refurbishing the trailing arms. Pressing out the old bearing from the inside. And here it is from the other side exiting the arm. New poly bushings going in Final assembly of the trailing arm A few installed (less brakes) pics. Rear brake caliper rebuild is next. Attached image(s) |
Lo-Fi Version | Time is now: 28th March 2024 - 03:45 AM |
