'73 Resto & Suby 6 Conversion, or a primer on "How to convert your 914 to a Subaru 3.0" |
76-914 |
Jan 9 2013, 10:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What's it been? A year since I got Blackie running. I finally get it tuned to a daily driver status and should have been happy as a Lark then but what do I do? I sold the engine (w/90 hour's on the Hobbs) on the last Dawn Patrol GMR run. So I pulled the engine and began preparing Blackie for her transformation.
Before I go any further check out my Jack Stands. Min height 19.5", 12 ton and should hold up to a 6.7 quake or direct nuclear attack. And out she comes. One thing you have to love about these cars is that you can remove an interior in 15 minutes. 30 min's if you have a console. This was one shot before the interior is gutted. and an hour later I'm scraping tar floorboards. |
76-914 |
Jun 27 2013, 07:03 PM
Needed something to do but I have the engine cleaned up and awaiting some seals. Then Aircraft Spruce sold me the wrong size 4130 tube so I can't start making motor mounts. (Notice how I blamed ACS. That felt good. Kinda relieves one of that nagging feeling brought on by accountability.) Herschel came by and picked up the Subaru skeleton today so that's done. Then I remembered the shock kit that Elyut sold me. Smoking deal, thx.
Left rear right rear left front right front I've always had a clunk as the rear lid was raised and lowered but basically ignored it. After I removed the old torsion bars and rollers I was able to see this. And before you say anything those are not my welds. Mine aren't nearly that good. I knew this area needed to be cleaned up but hadn't expected this. What is supposed to be there? A bearing? A bolt? A nut? I'll find out when I pull it apart I guess. The right side is gut sans the welds again. These welds look like someone tried to stick weld them on. Surely not factory. I have this side to reference if I don't get an answer. So Saturday I'll head back to ACS for the correct size 4130 tube to begin the motor mounts. This will be totally out of my league but Ian won't have any for a few month's (if ever) and I ain't getting any younger. (IMG:style_emoticons/default/dry.gif) That being said, what are the target dimensions for the engine height wise if I'm going with the suby 5mt tranny. TIA |
Lo-Fi Version | Time is now: 17th May 2024 - 08:13 PM |
