| 914Sixer |
Jan 10 2013, 05:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,509 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I have made several inquires about having new 914 CV joints made up. All the manufactures I contacted said it would take a run of 500 to get things rolling. There are no cost estimates at this point.
What is the price point you would like to see? $50-$100 per joint? Since there are 4 per vehicle, how many would you be interested in buying? Please know that these CV joints will be made in China. I am neutral on this because the companies are ISO 9000. |
| SLITS |
Jan 10 2013, 06:03 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
ISO Blah Blah means nothing other than their paperwork is in order. They can (and still) make shitty parts unless you are willing to be there in their factory from beginning to end to assure QC.
| ThePaintedMan |
Jan 10 2013, 06:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
I think the things like Chris Foley's Type 1 CVs still give us some options without a mass reproduction effort. IMHO, it would be more worthwhile to get decent quality, lower cost synchros. I think I remember talking to Mark (Mikey914) about those, but I can't remember what his thoughts were.
| 914Eric |
Jan 10 2013, 06:12 PM
Member ![]() ![]() Group: Members Posts: 316 Joined: 7-November 12 From: Northern Idaho Member No.: 15,125 Region Association: Pacific Northwest |
ISO Blah Blah means nothing other than their paperwork is in order. They can (and still) make shitty parts unless you are willing to be there in their factory from beginning to end to assure QC. (IMG:style_emoticons/default/agree.gif) I run an AS9100 certified manufacturing firm and I have to agree. It's nothing more than lots of red tape and paper pushing. Although we are an all american company and make high quality parts...Not Chinese junk. (IMG:style_emoticons/default/smile.gif) |
| Eric_Shea |
Jan 10 2013, 06:50 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
As long as they are GNK Loebros you could probably sell through 500 fairly quickly. The major parts suppliers are in need.
The Meyle and EMPI units hyper extend too far and will end up causing problems. We had a failure on McMark's car when we first started doing the CV's. Mark took the time to pull the cages and photograph the results. The first clue was how far the cage pressed out (with our fingers) on the cheaper units vs. the GNK Loebros. We looked at the holes in the cage and noticed they were cut differently. In Marks case, I believe he was powering out of a parking lot apron on to a road and powering on the throttle. The angle caused the control arm to extend, causing the CV to extend (in this case hyper-extend). Pretty common use of the vehicle if you think about it. Real world story as to why paying a "little" more for a better part pays off. I felt awful about it because Mark missed RRC that year... (IMG:style_emoticons/default/sad.gif) We learned the hard way. |
| 914Sixer |
Jan 10 2013, 08:38 PM
Sounds like we need to approach GNK about bring them back for a limited time.
| Tom_T |
Jan 11 2013, 10:40 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Sounds like we need to approach GNK about bring them back for a limited time. (IMG:style_emoticons/default/agree.gif) ... we need the OEM OE quality as originally made for & spec'd by Porsche for the CV's, not lesser quality - even if cheaper, cuz you'll be spending more on multiple replacements. I'm not sure what Chris does with the Type I CVs to upgrade them to T4/914 Porsche specs, but my long time P-car mechanic won't use type 1 CVs in a 914, and doesn't like them in later/higher HP Bugs, Ghias & Buses either. There were Chinese ISO9100 companies producint the acid-laced drywall, inferior steel, & supposedly "Stainless Steel", lead in painted products, etc. - so don't trust their QC without someone there 24/7 from your own company doing QC with full power to reject & shut down production. |
| Eric_Shea |
Jan 11 2013, 06:18 PM
QUOTE I'm not sure what Chris does with the Type I CVs to upgrade them to T4/914 Porsche specs, but my long time P-car mechanic won't use type 1 CVs in a 914, and doesn't like them in later/higher HP Bugs, Ghias & Buses either. They're the same CV... Just the outer casing is different for 4-bolts/2-pins vs. 6-bolts. Outer casing also differs with the gasket. So... Your P-car mechanic may not have used them but P did. (IMG:style_emoticons/default/biggrin.gif) |
| draganc |
Jan 11 2013, 07:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Why are you looking for a alternative if we already have a solution (Chris / Tangerine) within a good price in place?
I used his parts and they look and fit good. D |
| Eric_Shea |
Jan 11 2013, 10:37 PM
Because they are modified T1 CV's. We've been doing that to GNK Loebro's for years. I stopped becasue I got tired of all of the questions about the fasteners, flipping the inner race and what to do with the boot flange... yada, yada, yada.
It would just be nice to have the real deal to bolt on. 4 holes, 2 pins, proper gasket area and the same diameter mounting surface for the boot flange. 1. Type1 CV's have to be flipped over so the gasket mating area will match the 914 stub axle and tranny flange. 2. Then you either have to forego the gasket and use a gasket compound or... 3. do what Chris did and machine a groove for the gasket onto that face. When you flip them like that, they now have a step on the other end that doesn't fit perfectly into the boot flange so you either... 4. fill that with RTV or I think Chris uses... 5. an o-ring to seal that area. Then you have to... 6. use 2 of the 6 bolt hols for pins. Those need to be... 7. machined out to the size of the pins. Then... 8. the inner race needs to be flipped. Do all that and they're fine. You also have to make sure they're good quality. These are literally the knees of your car... bad knees and your SOL. Not a fun job to do twice. -or- Request that GKN Loebro make a batch of stock ones and bolt them on with new gaskets and schnorr washers and have a nice day. That's why... (IMG:style_emoticons/default/biggrin.gif) |
| ChrisFoley |
Jan 12 2013, 08:46 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,031 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Why are you looking for a alternative if we already have a solution (Chris / Tangerine) within a good price in place? I used his parts and they look and fit good. D What I'm offering isn't a true solution. Its a somewhat acceptable alternative to a lack of supply of the correct part. As Eric pointed out there are compromises. The work we have to do adds significantly to the final price. The brand my supplier provides doesn't match the precision standards of GKN-Lobro. But starting with Lobro Type 1 CVS and adding the same modificatons would likely increase the price by at least 25%. One customer has them in his 3 liter track car, so they seem to work ok, but they haven't been in service long enough to test their longevity. |
| 914Sixer |
Jan 12 2013, 10:43 AM
OK, I have contacted GNK about making CV joints and or complete axles. Lets see what they say. I will keep you posted.
| McMark |
Jan 12 2013, 11:10 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
QUOTE Real world story as to why paying a "little" more for a better part pays off. I felt awful about it because Mark missed RRC that year... I didn't miss RRC, but my car did. You'll be happy to know my car has forgiven you. (IMG:style_emoticons/default/biggrin.gif) I think the T1 GNK CVs are a perfectly good replacement. I think that leaving the CVs in the standard T1 orientation is a better compromise and use RTV to seal the joint (there is a time and a place for RTV). Less machining, less disassembly/reassembly, proper fit between boot and CV. The only thing you're really losing is the stock gasket, which I've seen 'smoosh' out on cars leaving the bolts loose. If I can't use a stock gasket, I'm fine with that. |
| draganc |
Jan 12 2013, 03:30 PM
Eric and Chris, you are both correct. My point is/was that even it's not perfect but we have a "solution" in place. Of course I wouldn't minde a oem type replacement at all!
I'm just wondering if the effort could/should be focused on a item that has no replacement in place. Of course this doesn't mean that the individuals can't spend their time on whatever is important to them. d |
| 914Sixer |
Jan 14 2013, 08:42 AM
*"MARK HEARD" <a914nut@email.com>*
------------------------------------------------------------------------ *Subject:* FW: Message from GKN Driveline website - Other - English *From:* Robert GenwayHaden *To:* a914nut@email.com *Date:* 01/14/13 07:01 AM Mark, Great e-mail address. Did you see the ‘Wheeler Dealers’ program on the 914 ? One of their best episodes. Anyway, can you send me the GKN part numbers of the joints and the shafts please ? These are 30 year old parts so some of our corporate knowledge leaks as people retire but we can always retrieve the drawings from a part number. GKN typically doesn’t operate in the aftermarket, but we do have a motorsports division that may be able to organize and distribute a batch of these parts. Do you think that ‘914World.com’ might be able to organize a group purchase ? Alternatively a company like UTS may be willing to hold and distribute a batch of shafts. Send me the numbers please and let’s see what is possible. Regards, Rob. The following message was submitted on the GKN Driveline website: From: Mark Heard Organisation: Address: 134 Stonegate South City: Boerne, TX 78006 Country: USA Telephone number: 210-262-4226 Fax number: Email: How did you hear about us: Word of mouth Further info: Comments: The fans of the Porsche 914 would like to know there is any possibility of making new CV joints and or complete axles for the 1970-1976 914. The 914World.com currently has over 6,000 members. We are in need of these restoration parts This is the reply I got back from GKN. Lots of possibilities here. |
| Eric_Shea |
Jan 14 2013, 11:04 AM
I think you should hook them up with SSF and IMC Parts. I can let my reps know... Otherwise, I can contact Pelican and Stoddard and see what they'd be willing to take as well.
| Cap'n Krusty |
Jan 14 2013, 11:08 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I'd be wary of listening to anyone who thought the Wheeler Dealers 914 episode was " One of their best episodes". I noted a number of serious errors in what Edd did and how/why he did it. Like the BS external cooler, which is the LAST thing the car needs in the UK.
The Cap'n |
| rick 918-S |
Jan 14 2013, 01:38 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,298 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I'd be wary of listening to anyone who thought the Wheeler Dealers 914 episode was " One of their best episodes". I noted a number of serious errors in what Edd did and how/why he did it. Like the BS external cooler, which is the LAST thing the car needs in the UK. The Cap'n Your a funny guy! (IMG:style_emoticons/default/lol-2.gif) It's TV silly! (IMG:style_emoticons/default/biggrin.gif) Nice to see some movement on this. The last batch of CV's I used I assembled from the best pieces I could salvage from the used parts bin. There on the Alien. Not the best idea I know but hey, it's what I had. (IMG:style_emoticons/default/unsure.gif) I'm out of used joints. |
| Tom_T |
Jan 14 2013, 01:57 PM
IIRC full axles with the 2 CVs were still available from Porsche.
| jsayre914 |
Jan 14 2013, 05:17 PM
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,210 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I am interested, I hope to one day Tear a CV in half with the RAW POWER of my Porsche.
(IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 7th July 2026 - 12:48 AM |
