Rabbitt Flares |
Rabbitt Flares |
Crawf |
Jan 20 2003, 10:11 AM
Newbie Group: Members Posts: 24 Joined: 20-January 03 From: Berkshire, England, UK Member No.: 171 |
I'm considering doing a wide arch conversion to my fourteen and was weighing up the options.
Does anyone have pictures of the 914 with Rabbitt (Golf) flares? Ideally I'm looking to get 17 x 7 or 8 at the front and 17 x 8 or 9 in the rear. |
SilverBullet |
Jan 29 2003, 08:53 AM
Member Group: Members Posts: 71 Joined: 30-December 02 From: San Jose, Ca. Member No.: 53 |
There's actually quite a few different trim pieces that were made for the rabbit. There was both a very small metal trim peice, and a couple of differnt plastic trim peices. The metal version was VERY small (natural aluminum color) and it covered only about 1 inch of the lip, of the flare. There were three different plastic versions. One was black and covered 95% of the flare, then there was one that was smooth and painted to match which was also 95%, lastly there was a very small platic trim peice like that seen on some of the 1980's style 911's, it was only on the rear flares and it was only on the leading edge, black in color.
Jay |
chunger |
Feb 5 2003, 04:19 PM
Member Group: Members Posts: 409 Joined: 11-January 03 From: Albany, CA Member No.: 133 |
Question about installation for those who've done it. . .
How much of the Rabbit fender do you need? Is it similar to the factory M471 kits? Leave a couple inches 'round the edges? Also, on istallation, do you cut exact and booty weld them in? Or do you overlap the flares on and lap weld them? Ed Mayo's racecar looks like it has 16x7 fuchs on it. . . were there spacers involved there? Or was it bolted right up. . . I just got a set of 16x7's and would like to run 225/50's on them w/ a cheap set of flares. . . of course, by the time I calculate time spent (IMG:style_emoticons/default/ar15.gif) . . . welding them in, it'd have been cheaper to buy a set of fiberglass fenders. . . oh well, work harder, not smarter (IMG:style_emoticons/default/blink.gif) . -'Chung |
Jeroen |
Feb 5 2003, 04:32 PM
225's on a 7x16 is too wide IMO
The tire will flex all over the rim when sideloaded The grip you think you will gain with the 225's over 205's is lost in the deflection of the tire I'd even dare to state that it handles worse with 225's than with 205's YMMV... Jeroen |
Feb 5 2003, 04:37 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Jeroen @ Feb 5 2003, 02:32 PM) 225's on a 7x16 is too wide IMO The tire will flex all over the rim when sideloaded The grip you think you will gain with the 225's over 205's is lost in the deflection of the tire I'd even dare to state that it handles worse with 225's than with 205's YMMV... Jeroen i dare to object (IMG:style_emoticons/default/smile.gif) i run 225/50 x 15 on my 7" and they fit perfectly. even under heavy side-load ... mhmmm, i don't have a closeup foto of the tires, that's the best i can get: (IMG:http://www.sirandy.com/pix/914/09.01.2002/IMGP0617.JPG) Andy |
chunger |
Feb 5 2003, 06:03 PM
Interesting. . .
From looking at the tire specs, seems 225 is pretty standard on a 7" rim. Most tires seem to specify 6"-8" rims so I'm cutting it right down the middle w/ the 7" fuchs. Tread width is 7.9" on the bridgestone Potenza's. I've got 215/40 R16's on there right now, and they look like they could stand to come out 10mm no problem. Street car. . . a little extra rim protection is not a bad thing for me. These just need to get the car on the road and hold me over 'til the fiberglass and (IMG:style_emoticons/default/devil.gif) 345/35 15's go on the back (IMG:style_emoticons/default/smile.gif) Already have the rims and tires for that. . . just can't afford the body panels just yet. -'Chung |
seanery |
Feb 5 2003, 06:27 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
911's with 6's and 7's had 225's on the rears, right?
My 86 951 had 205's on 7's and 225's on 8's (FUCHS), I plan on running at least a 225 on the front of the 914 with the 8's from the 951. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:09 PM |
