Firewall Bushing Install |
microsa |
Nov 10 2004, 04:17 PM
Member Group: Members Posts: 94 Joined: 20-February 03 From: San Antonio, Tx Member No.: 329 |
I need to replace the firewall bushing on YellowDog. I've got everything ready and shift linkage out of the way. The old one was not there (surpirse) and I have been tring to get the new on in with no luck. I've tried a large deep socket and a mallat, but so far all i've got is a busted knuckle. Anyone got any secret tricks?
TIA Mike Allen SA,TX |
Nov 10 2004, 04:22 PM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
put it in a cup of water and heat it up in the microwave.
that'll soften the plastic. then pound on it with a BFH ... (IMG:style_emoticons/default/smash.gif) Andy |
jim912928 |
Nov 10 2004, 04:27 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
do that..it works. Mine went in with thumb pressure (tried it cold and no way)
microsa |
Nov 10 2004, 04:43 PM
Hot water and larger BFH did the trick! Now, to deal with that flattened out finger that got in the way. Hard to type.
Thanks |
ematulac |
Nov 10 2004, 07:55 PM
914 addict Group: Members Posts: 540 Joined: 24-November 03 From: Palmdale, CA Member No.: 1,382 |
I worked the edges in with a screwdriver. Worked for me, but YMMV.
joea9146 |
Nov 10 2004, 08:30 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
QUOTE(microsa @ Nov 10 2004, 06:43 PM) Hot water and larger BFH did the trick! Now, to deal with that flattened out finger that got in the way. Hard to type. Thanks You can try putting your finger in the Microwave.... (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 07:27 AM |
