Headlight asembly, assembly of headlights |
kenrinc |
Jan 19 2013, 01:22 PM
Newbie Group: Members Posts: 10 Joined: 12-February 09 From: BayArea, CA Member No.: 10,045 Region Association: Northern California |
I'm in the process of putting together the headlights in my early 72. The lift rod passes into the headlight bucket through a "brush". I think I have them on the right side but am unsure of what hardware was used to secure them. The hole just look like they used sheet metal screws. If so do they point out into the trunk or into the bucket?
Took 1000s of pics and don't have one of this. LOL (IMG:style_emoticons/default/biggrin.gif) Thanks Ken Attached image(s) |
scotty b |
Jan 19 2013, 01:32 PM
just like that (IMG:style_emoticons/default/beerchug.gif)
914Sixer |
Jan 19 2013, 02:32 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If you are not going for the original look, you might want to update to the later rubber cover that goes over everything, It does a better job of keeping the moisture out.
scotty b |
Jan 19 2013, 03:01 PM
just curious, is this a 4 or a 6 ?
kenrinc |
Jan 19 2013, 03:05 PM
It's a 4. Thanks guys. May have a couple question later. Can't believe I never took a pic when disassembling these.
Ken |
Lo-Fi Version | Time is now: 21st May 2024 - 06:14 PM |
