What is this plug...., and does it need to be connected? |
billh1963 |
Jan 20 2013, 01:22 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
jhora |
Jan 20 2013, 01:23 PM
Newbie Group: Members Posts: 26 Joined: 6-March 09 From: Kentucky Member No.: 10,138 Region Association: South East States |
Fuel Pump
ConeDodger |
Jan 20 2013, 01:25 PM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Yes Bill. It lets all the magic smoke out of the electrical system... (IMG:style_emoticons/default/av-943.gif)
Seriously, I can't tell where you are on the car. You're too close... |
billh1963 |
Jan 20 2013, 01:29 PM
Yes Bill. It lets all the magic smoke out of the electrical system... (IMG:style_emoticons/default/av-943.gif) Seriously, I can't tell where you are on the car. You're too close... Under the battery.... The car has carbs and runs fine. Just wondering if it might be important! |
Gint |
Jan 20 2013, 01:40 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Yup, fuel pump. Don't cut it off like the PO of my car did. You can rig the relay board to use that connector with your carb fuel pump.
scotty b |
Jan 20 2013, 01:47 PM
(IMG:style_emoticons/default/agree.gif) Original fuel pump. Your car has a hot wire pulled off of the coil, ( that's what that fuse is for ) and a ground going straight to the case to power the aftermarket pump that was on the car.
Lo-Fi Version | Time is now: 21st May 2024 - 02:01 PM |
