electric H20 pumps on V8 conversions, any help? |
vinniedatorch |
Jan 20 2013, 11:48 PM
Newbie Group: Members Posts: 40 Joined: 12-January 13 From: Lakewood Ca. Member No.: 15,358 Region Association: Southern California |
can someone help recommend an electric water pump for a V8 conversion?
Mike Bellis |
Jan 20 2013, 11:56 PM
Look for something between 20-30 GPH (Gallons Per Hour).
A lot depends on what radiator you run. What size hose you run. What type of V8 you run... many variables. A stock Chevy pump runs around 30 GPH. |
mittelmotor |
Jan 21 2013, 12:45 AM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Meziere makes quality stuff, but not cheap. They have both block-mounted and remote pumps.
messix |
Jan 21 2013, 01:28 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
stay away from the "race" style ones. they are meant for drag race engines or short duration running and not constant duty cycle. several here http://www.jegs.com/c/Cooling_Electric-Pumps/10135/10002/-1
bulitt |
Jan 21 2013, 07:44 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
You can use a Meziere pump and mount it in a remote location. If you bolt it to the block it will hit the firewall. The Meziere has one inlet and two outlets. You connect it to the water pump inlet passages on the block with 90 degree fittings.
Picture of a Meziere remote pump (IMG:http://www.914world.com/bbs2/uploads_offsite/www.meziere.com-13632-1358775847.1.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-12479-1299724114_thumb.jpg) Fittings You will need (IMG:http://www.914world.com/bbs2/uploads/post-12092-1349377478_thumb.jpg) Another option is to use the dedenbear water manifold and dedenbear remote pump. (IMG:http://www.914world.com/bbs2/uploads/post-13632-1349395275.jpg) Both the Meziere and dedenbear units are expensive but both have useful lives of over 3000 hrs. Neat thing about the remote pumps- it allows you to use the stock fuel pump. Another pic of the Dedenbear set up. (IMG:http://www.914world.com/bbs2/uploads_offsite/i216.photobucket.com-2923-1293483015.1.jpg) I have two fittings for sale if you need them- (IMG:http://www.914world.com/bbs2/uploads/post-13632-1345679355.jpg) Water Pump/block Fittings SBC |
914GT |
Jan 21 2013, 10:23 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I've been using the Dedenbear pump (my engine with the yellow oil pan above) for almost 10 years and around 10K miles without any problems. These pumps can be rebuilt with new seals and brushes but I've never had a reason to take mine apart.
Guy T |
Lo-Fi Version | Time is now: 14th May 2024 - 10:42 AM |
