Zombie Thread |
Zombie Thread |
Mike Bellis |
Jan 21 2013, 09:35 AM
Lately many zombie threads are popping up. Is it possible to purposely create a zombie thread that pops up in every search?
Here are some sample keywords... without conjunctions... feel free to add you own before this thread gets locked or deleted... (IMG:style_emoticons/default/evilgrin.gif) Keywords: 914 911 944 928 356 -6 -4 T4 FI EFI L D Jet GT steel fiberglass clutch brakes cooling mirror clock PO DAPO WCR PCA welding bondo wiring schematic connector fuchs BBS aluminum Porsche ebay trailer towing free engine tin fan heat tires rubber gasket exchanger flare TIG MIG Oxy narrow 5 lug center console VIN prototype headlights running timing spark plugs reverse tube members club original restoration modified correct suspension springs shocks sway fog switch vintage custom bender sand blast acid dip soda metal prep LS1 V8 turbo Audi VW Chevy heater cooling engine motor POS BS tach tachometer adapter fuel mileage Renegade radiator oil brad penn interior seats carpet dyno gear transmission shift tranny cv boots shifter console axle torsion bilstein kyb koni mono momo hub steering tires rims RUF bus motronic megasquirt aftermarket 901 915 G50 Boxster carrera duck wing spoiler drag lift targa roll bar harness pin progress build thread FS WTB forum design bent broke thrashed bumper chrome early late euro side marker hella lamps bulb header exhaust gasket valve cover case crack deck height cylinder head rebuilt thief warning water salt auction race renn danke Subaru Subi cradle retrofit shaft body paint primer dent weld hammer fabricate BTDT route 66 project meeting coffee cars Porsche old school taco plate tuna can pressure CHT O2 WB NB IAT MPS TPS vacuum leak pressure how install dog bone bumpers garage jack stands floor epoxy JB clock driver passenger fuse panel relay board pop up round Bosch wire cigarette white black orange green yellow silver blue grey delphi DOS DDOS hacker metalic clear ebay copart list sale free pad panel door hood trunk roller pulley duplicate original creamcicle limited LE 1970 1971 1972 1973 1974 1975 1976 bucket LED master pedal fuel tank sender brass pad longs chassis control arm cover rug antenna radio dash cluster seat belt bolt center back bonnet grommet tube control injectors ignition pertronix 009 011 050 distributor COP coil pack trigger points wiper delay horn tits 916 AIR GTS Germany Stuttgart European pictures BBQ build party type original project glove box cable adjustment window trim stainless pillar carburetor IDF IDA filter hat tin thermostat expansion header tube flange rusty design bushing elephant cross member 1.7 1.8 2.0 2.2 2.4 2.7 2256 1910 badge emblem decal placement hinge jam rocker getty Raby adjustment factory member buy upholstery basket weave carpet bolster side rear vinyl jig brace shirt sweat work ljet djet Engman latch hood trunk door regulator alternator gap perlon tunnel towing glove box case main cam crank lifter rods stainless MSD crane wires schematic diagram pictures attachment url img bore stroke ventilated tarret Patrick original customs MSDS bergman Raby lift duration struts swing bushings poly bronze visualizer thread rennsport roll polybronze lexan plexyglass help pooling leak oil AA AAA NARP world pelican brumos canepa hershey swap rust repair chassis hellhole hell hole floor pans doors paint longs help shop bodyshop painting restore inspection ppi unicorn restoration Gugelot story got Ferdinand Alexander Porsche fiat x19 escape PCA Panorama Cayman Boxster ceyenne rabbit GTI Golf PMB watercooled water heater targa Audi stroker turbo Bowlsby Pelican Atlanta M41 GT wiki parade red rocks California Cayman Panomera Panorama Cayenne mille concourse concore QRS AIR autox time attack trial pikes peak daytona Atlanta La Mans nurburgring ATS help phone dial powder coat Hosier chrome tits steel carbon fiber |
Andyrew |
Jan 21 2013, 10:35 AM
I like this (IMG:style_emoticons/default/smile.gif)
Jan 21 2013, 11:54 AM
Lately many zombie threads are popping up. I have been debating to disable the "bump" for poll threads after someone voted in the poll. That way, one has to actually post to bump a thread and then we know who is resurrecting them dead threads. (IMG:style_emoticons/default/evilgrin.gif) |
Mark Henry |
Jan 21 2013, 03:08 PM
Kind of neat to click on the member names, you find out who is still around, who lurks every so often and who dropped off the face of the world and when.
BTW the third option should have been "you were looking for "brains". |
SLITS |
Jan 21 2013, 06:18 PM
I blame Dave ... the consummate Canadian.
Jeff Hail |
Jan 21 2013, 09:52 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Here we go again. I see dead 914's !!!
balljoint |
Jan 22 2013, 10:24 AM
I blame Dave ... the consummate Canadian. Brrrraaaaaaaainnnnnnss Eh! Don't blame me, I'm innocent. (IMG:style_emoticons/default/confused24.gif) |
Mark Henry |
Jan 22 2013, 12:59 PM
I blame Dave ... the consummate Canadian. Brrrraaaaaaaainnnnnnss Eh! Don't blame me, I'm innocent. (IMG:style_emoticons/default/confused24.gif) Yehhhh.....riiight...... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 11:17 AM |
