Valve Adjustment, Unable to adjust |
majorpikins |
Jan 23 2013, 12:31 PM
Newbie Group: Members Posts: 2 Joined: 31-July 12 From: corona Member No.: 14,742 Region Association: Southern California |
In preparation for doing a valve adjustment on my 73 1.7 (1.9 big bore) I put the engine in TDC for cylynder one by locating the groove on the upper most part of the flywheel. There also was some sort of mark appearing in the V at the fan housing. When I went to do the adjustment on the number 1 cylynder I was unable to get the feeler gauge under adjusting screw of the intake valve. It appears to be in the open position. Upon examination I noticed that the destributor rotor is pointing to the number 3 cylinder wire location? I just got the car recently and it was running fine except for some backfiring upon deceleration. Any ideas what is going on here?
Rockaria |
Jan 23 2013, 12:35 PM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
In preparation for doing a valve adjustment on my 73 1.7 (1.9 big bore) I put the engine in TDC for cylynder one by locating the groove on the upper most part of the flywheel. There also was some sort of mark appearing in the V at the fan housing. When I went to do the adjustment on the number 1 cylynder I was unable to get the feeler gauge under adjusting screw of the intake valve. It appears to be in the open position. Upon examination I noticed that the destributor rotor is pointing to the number 3 cylinder wire location? I just got the car recently and it was running fine except for some backfiring upon deceleration. Any ideas what is going on here? You are not at top dead center for #1. Spin the engine till the distributor points to #1 position and you will see the groove on the flywheel line up like before. Then check. Things should be better and able to adjust. |
mrbubblehead |
Jan 23 2013, 01:06 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
You need to rotate the engine 360 degrees. clockwise or anti-clockwise, it dosn't matter at this point.
Rand |
Jan 23 2013, 01:09 PM
Wrong stroke
Kirmizi |
Jan 23 2013, 01:43 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
In preparation for doing a valve adjustment on my 73 1.7 (1.9 big bore) I put the engine in TDC for cylynder one by locating the groove on the upper most part of the flywheel. There also was some sort of mark appearing in the V at the fan housing. When I went to do the adjustment on the number 1 cylynder I was unable to get the feeler gauge under adjusting screw of the intake valve. It appears to be in the open position. Upon examination I noticed that the destributor rotor is pointing to the number 3 cylinder wire location? I just got the car recently and it was running fine except for some backfiring upon deceleration. Any ideas what is going on here? You are not at top dead center for #1. Spin the engine till the distributor points to #1 position and you will see the groove on the flywheel line up like before. Then check. Things should be better and able to adjust. (IMG:style_emoticons/default/agree.gif) The popping on decel could be an exhaust leak, or running rich. Mike |
majorpikins |
Jan 23 2013, 02:15 PM
OK got it thanks guys!
mr914 |
Jan 23 2013, 05:33 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I've seen a couple of cars where the distributor gear was installed 180 degrees out.
Had me scratching my head when Iran into this When you verify #1' trace the plug wire to ensure |
Lo-Fi Version | Time is now: 21st May 2024 - 05:19 AM |
